Voyager Bookmarks (warning: many images!)
  • Targhan
    Posts: 2833 from 2003/2/8
    Hey guys, I wrote up a "quick" set of ARexx scripts to get CManager bookmark association with Voyager again. You'll need rmh.library and RxCManager.library for the scripts to work. Anyway, here is the LINK.
    :idea:Targhan
  • »05.10.03 - 03:15
    magnetic
    Posts: 2129 from 2003/3/1
    Thanks Targhan
    You are indeed a valuable person in this community!
    magnetic
  • »05.10.03 - 05:15
  • Targhan
    Thanks Magnetic!
    The real credit would belong to Alfonso Ranieri, since he created the libraries used. I just put them to use :-)
    :idea:Targhan
  • »05.10.03 - 05:34
    DSLCC
    Posts: 246 from 2003/5/14
    Very cool! :) Thanks!! :-)
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »05.10.03 - 15:40
    Robert
    Posts: 331 from 2003/5/12
    Oooh - I missed this.
    I'll try it tonight.
    Cheers targhan!
    Robert.
  • »08.10.03 - 14:37
    Jupp3
    Posts: 1193 from 2003/2/24
    Now, if there was just new stabile release of Voyager... :-)
  • »08.10.03 - 14:59
    Robert
    Not sure quite what I did but I've made a complete arse of this -
    :roll:
    My Back button now doesn't work and I have an "book" icon for hotlist
    which does hee-haw! :lol:
    No great tragedy but typical Wilse, ballsing it up! :-D
    Robert.
  • »09.10.03 - 19:09
  • Targhan
    Oki doki, I'll try to help you in just a few. But first, you must always wach your Tiggers!
    hehehe
    :idea:Targhan
  • »09.10.03 - 19:16
    Robert
    @Targhan:
    So which one are you?
    (And if you're Roy, get well soon.) :-D
    Robert.
  • »10.10.03 - 00:14
    Robert
    Okay, here are the prefs and setting for my toolbar
    Cheers targhan. I'm at work just now but I'll try fixing it when I get home.
    Robert.
  • »10.10.03 - 10:51
    Robert
    @Targhan:
    Thanks to your images I've restored my back button and created the new
    two, however when I click them, nothing happens.
    I put the scripts in S: in both the system partition and
    sys:morphos/S .
    Still, better than it was, thanks.
    Robert.
  • »10.10.03 - 19:08
  • Targhan
    does ARexx work on your system? did you list the type of command as AmigaDOS?
    :idea:Targhan
  • »10.10.03 - 19:13
    Robert
    @targhan:
    I've never used ARexx for anything - how do I check if it's working?
    The command type is listed as AmigaDOS.
    Robert.
  • »10.10.03 - 20:00
  • Targhan
    open a shell and type the following line:
    rx 'say "hello world"'
    If the shell window returns "hello world," then you know it is working. You may get a requester if it isn't.
    :idea:Targhan
  • »10.10.03 - 20:26
    Robert
    Ahaaa... that explains it. Server not active.
    So how do I activate the beast? :-)
    Robert.
  • »10.10.03 - 20:33
  • Targhan
    Sounds like you need to activate ARexx ;-)
    :idea:Targhan
  • »10.10.03 - 21:32
    Robert
    :lol:
    I hear ya but how do I do it?
    Robert.
  • »10.10.03 - 21:40
    zacman
    Posts: 86 from 2003/2/26
    Start RexxMast.
  • »10.10.03 - 21:50
    cecilia
    Posts: 459 from 2003/8/30
    put Rexxmast in your wbstartup dir.
  • »10.10.03 - 23:00
    Robert
    OK - did that. Rexxmast now starts on startup but doesn't seem to recognise commands, ie. rx 'say "hello world"'.
    Robert.
  • »14.10.03 - 09:39
    cecilia
    do you have all the right rexx libs installed??
    i ain't no expert, but there is a FAQ on this site which addrresses the "how to install or use Arexx", so i'd run there and check it out. :-D
  • »14.10.03 - 14:45
  • Targhan
    Try running snoopdos before testing rexx, it should tell you what is missing.
    :idea:Targhan
  • »14.10.03 - 17:08
