PCMCIA Wireless NIC on A1200/MOS
    Dragster
    Posts: 98 from 2005/11/6
    I've got a PCMCIA wifi nic running under OS4 and OS3.9 using the prism2 driver from aminet. I'm using the cardpatch and cardreset tools from aminet successfully too so that the NIC is ready to go after a reset.. however this is not working under MorphOS.. sometimes miami works with the driver, others it doesn't and complains that it can't open unit 0 of prism2. device... when I run the above mentioned tools in the morphos user startup script, the system freezes at boot... (it's actually cardreset the tool that makes MOS hang)...
    Help please!
    Cheers
  • »15.05.09 - 00:27
    Posts: 1516 from 2003/2/24
    You dont need cardreset tools in MorphOS. Unfortunately I can not help with the driver problem.
  • »15.05.09 - 09:25
