Genesis problem
    MikePig
    Posts: 10 from 2003/10/11
    Hi
    After installing the genesis demo from aminet on my peg, the wizard work, the main application too but the preferences freeze while loading...
    What's happening ?
    TIA
  • »13.10.03 - 00:05
    Posts: 90 from 2003/4/13
    <preferences freeze while loading...>
    Run snoopdos before you start Genisis and you will see
    in the output window of snoopdos what's missing or wrong
    regs
    hgm
    MiamiDx 1.0c is a lil better than Genisis:-)
  • »13.10.03 - 07:34
