AGA demos & games 68k compatible with MorphOS
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    fASTEr ! ! !
    tbl - ocean machine _ 100% compatible demo speed up roxx
    tbl - starstruck _ 100% compatible demo speed up roxx ^ party version exit you must restart os
    tbl - requiem _ 99% compatible demo speed up roxx ^ end part screen picture flash white textures on screen
    tbl - little nell _ no compatible demo ^ fasttracker player crash on start demo
    nvx - relic _ first part ok demo speed up roxx ^ next part feez on animation pyramide with arka up
    ptn - gift _ start ok demo speed up roxx ^ player dbm crash music stop animation
    lns - hotstyle takeover _ no compatible demo ^ black screen and vertical textures
    all test run on A1200 AGA (NOGFX!) BPPC 240MHz MOS145 emu 68k interpretaion / JIT Trance v50.7
    best start AGA progz add startup-sequence after trance and set up 127 taskpri and remove before gfx driver
    please write here other your test demos and games run!
    [ Edited by SKOLMAN_MWS on 2007/1/14 9:37 ]
    _
  • »12.01.07 - 03:59
    MarK
    Posts: 641 from 2004/1/25
    i thought, that MOS doesn't work without a gfx board... this is great news! how is the feel of the aga system speed under trance?
    bye, MarK.
  • »07.03.07 - 07:06
    Posts: 109 from 2006/9/10
    Errr... so how exactly did you do it? Did you load the AGA-demos from startup-sequence or what?
    Could you maybe quote your startup here - that might clarify a few things.
  • »08.03.07 - 21:08
    SKOLMAN_MWS
    @MarK & All
    morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4874&forum=42
    @quadpol
    load gfx drivers enable cgx 56kHz audio "1"
    in startup-sequence disable load gfx drivers.
    ;LoadMonDrvs
    Trance
    demo.exe
    Permedia2
    LoadWB
    start normal with OS disable paula 56kHz audio env set "0" 8-)
    _
  • »09.03.07 - 20:47
    Edit: Woohoo! Finally made it working. Speed is indeed very high, esspecially compared to running it on a lowly 30Mhz 040 through OS3.9! Don't know how speed on my 210Mhz PPC compares to running it natively on 68060 though.
    I put all the stuff on my secondary MOS-partition (lower bootpri) with the demo s-s. Maybe I'll later make a small script for selecting between different demos.
    Actually quite a large number of AGA demos seem to be working. Trance is impressive.
    [ Edited by quadpol on 2007/3/14 1:16 ]
  • »13.03.07 - 22:55
    SKOLMAN_MWS
    Hi All :-)
    http://rapidshare.com/files/62510728/GIFT_run_on_MorphOS_BlizzardPPC_by_Skolman_1.mpg
    http://rapidshare.com/files/62512051/GIFT_run_on_MorphOS_BlizzardPPC_by_Skolman_2.mpg
    _
  • »14.10.07 - 20:44
    crespowu
    Posts: 1 from 2008/1/22
    It sounds unbelievable.
  • »22.01.08 - 06:35
    danielrigano
    Posts: 1 from 2008/1/24
    Thanks for the explanation of these acronyms.
    400mw green laser pointers
    [ Edited by danielrigano on 2008/3/21 13:16 ]
    [ Edited by danielrigano on 2009/8/31 18:06 ]
  • »24.01.08 - 13:07
    SKOLMAN_MWS
    The Black Lotus - Ocean Machine on MorphOS
    http://pl.youtube.com/watch?v=DuzY7pXTQ10
    _
  • »27.08.08 - 17:18
    SKOLMAN_MWS
    Appendix - I Want To Be Machine on MorphOS
    http://youtube.com/watch?v=6DAaD99fmF8
    _
  • »23.10.08 - 08:48
    skipp604
    Posts: 56 from 2003/8/21
    Now please write a tutorial how to run some OS-legal demos on a machine without AGA or Paula - that means my Efika, for example =)
    bplan Efika 5200B, ATi Radeon 9250 / 256 MB, MorphOS 2.4
  • »10.01.09 - 14:03
    Sir_Lucas
    Posts: 112 from 2006/4/23
    That'd be something...:D
  • »10.01.09 - 16:45
    skipp604
    I tried with a combination of 'eaudio.device' and ModePro but no luck as of yet... I know I'm doing something wrong, but then again - most demos even if they open their own screen, use a The Player 6.1 routine which bangs the audio HW directly... so really no way around that...
  • »10.01.09 - 20:11
