Voodoo4 PCI/AGP
    Posts: 1068 from 2003/3/24
    Is somebody using a Voodoo4?
    And what about the 3D support since MOS 1.4 there is a Warp3D wrapper for Voodoo3 and 4, i've got a Voodoo3 but would like to upgrade to Voodoo4, and now i want to know, if there are any problems with the Warp3D wrapper and the Voodoo4 and if somebody is using a TV-Card with his Voodoo4?
  • »19.09.03 - 20:19
    Posts: 261 from 2003/3/13
    I got a Voodoo4AGP, and the warp3d games
    work good here :)
    I even can change my brightness settings
    and stuff in the monitor prefs, while a
    friend of me with a voodoo3 says it crashes
    his system.
    Bye,
    Felix.
  • »19.09.03 - 22:33
    Posts: 140 from 2003/9/16
    I have voodoo 4500 AGP and I wanted to uograde to a faster Radeon.
    There is FULL support for the radeon on MOS?
  • »20.09.03 - 00:00
    zacman
    Posts: 86 from 2003/2/26
    No, there is no 3D support yet and overlay is
    currently disabled for radeon 8500/9100. DVI
    output works.
  • »20.09.03 - 01:55
    Hi Felix did you have any TV-Card running on your system, with the AGP Card? I heard that there are problems with TV-Cards when your are using an AGP GFX Card!
  • »20.09.03 - 02:16
    No, i had a TV Card on my old Mediator setup,
    worked good, i have given it to my buddy, who
    has a pegasos + voodoo3, and we still have to
    test it out, we are playing quake2 to much
    online, instead of doing this kind of stuff :)
    Bye,
    Felix.
  • »20.09.03 - 16:17
    Posts: 12 from 2003/8/7
    I use a Voodoo4 4500 AGP and all my
    3D-Games runs perfectly.
    But, a small problem is, the scaler-function
    (overlay) crashes the system when you play
    a video with mplayer after a 3d-game has run.
    A voodoo3 has not this problem!
    But, and this is the best:
    A Voodoo3 has 25percent more 3d-power.
    Heretic2 and Quake2 runs smoother and
    WipeOut is nearly unplayable :-)
    TV-card with AGP-boards?
    Simply: NO! The Articia-S does not allow
    a busmaster-transfer over the "slave"-AGP-bus!
    TV-card with a PCI-graphic-card runs,
    when you use the Visionary-soft!
    Bye
  • »20.09.03 - 19:47
    The Voodoo3 has a better 3D performance?
  • »20.09.03 - 22:17
    Jupp3
    Posts: 1193 from 2003/2/24
    I had Voodoo 4 4500 connected to my Pegasos, it didn't work...
    Fan on it started on power up, but there was no image coming through... Still, I could hear my Pegasos boot to MorphOS - Even if I tried to abort with ESC...
    I guess that was a broken card, returned it and got refund...
    But tell, if you have similar problems, and when buying, keep proof-of-purchase, so you can return it, if it doesn't work
  • »21.09.03 - 08:32
    @ThePlayer:
    Sorry, i meant the Vooodoo4 with the better
    performance. :-) It was an typing error...
    But, my new problem is the fan on the Voodoo4.
    It was an used card (ebay) over a long time.
    Now the fan makes many noises!
    Ich hope, i can find a new one for replacing!
    Bye
  • »25.09.03 - 07:10
