Soundblaster
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    I've been using on board sound so far. I've just (30 mins ago) installed an SB_Live 5.1 and am unable to hear anything from it. I put it in the PCI slot furthest from the AGP. Is there something else to set?
    On board sound still works fine.
    Thanks,
    Robert.
    Robert.
  • »20.09.03 - 12:58
    GMKai
    Posts: 253 from 2003/4/7
    is there a driver for that card available?
    did you change ahi-settings?
  • »20.09.03 - 16:49
    Posts: 157 from 2003/3/3
    MorphOS does not have Emu10k1 drivers in normal distribution (at
    least on 1.4) so you'll need to download them on net.
    http://www.lysator.liu.se/~lcs/files/ahi/beta/
    ppc-morphos-ahiusr-5.10.lha
    It has files EMU10KX and emu10kx.audio
    copy EMU10KX to devs/audiomodes and emu10kx.audio to devs/ahi
    after those.. (and reboot?) you'd ought to able to select Emu10k1 from
    Ahi prefs.
    http://somequicknotes.blogspot.com/index.html
  • »20.09.03 - 18:30
    Robert
    @Joanna:
    I'm downloading it now, thanks.
    Will let you know if it works.
    Cheers,
    Robert.
    -EDIT-
    I don't appear to have audiomodes or ahi drawres in my devs drawer.
    Should I just create them?
    Thanks again,
    Robert.
    Robert.
  • »21.09.03 - 10:24
    roschmyr
    Posts: 206 from 2003/2/20
    @Robert
    no need to create the drawer, you've them already
    look at mossys:devs/
  • »21.09.03 - 12:12
    Robert
    @roschmyr:
    Ahhh... thanks.
    It's working now! :pint:
    Robert.
  • »21.09.03 - 13:30
    Miky060
    Posts: 694 from 2003/2/24
    in occasion of Pianeta Amiga fair I mounted a SB_Live 5.1 board in my PegasOS too. I was convinced that with this board audio problems of Pegasos would be eliminated 'cause I read a similar comment by Matin Blown (is the spell correct?), but I sadly can say that sound distortion is still present moveing windows! :-(
    However the typical "slow down" audio effect has gone away.
    ...better than nothing...
  • »23.09.03 - 09:14
