monkey island 3 scummvm
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys is there a way to play the cd version (pc) of monkey island 3 with scummvm????
  • »06.08.03 - 22:59
    realstar
    Posts: 298 from 2003/2/24
    I just gave Monkey3 a try and it runs quite
    well, but seems to have a few problems still.
    It stopped and went to a debug console after
    playing for a bit. To play it from CD use these
    options on commandline: "datapath cd0: comi"
    (I use an iconx script to launch)
  • »07.08.03 - 03:20
    klapdeur
    i have it workong now but when i save or try to load scummvm crashed is this a bug of scummvm???
  • »07.08.03 - 14:46
    mahen
    Posts: 118 from 2003/2/24
    Just tried Monkey 3, french CD version, with the lastest ScummVM... It works but... It's awfully slow. (videos are at about 1 FPS, and during the game, the mouse pointer is very slow too)...
    Is it normal ? :-)
    I remember the PC engine worked very fast on a cyrix 166+ machine :) - I mean the original game :)
    xmpp:mahen on jabber.fr
  • »19.09.03 - 12:36
    mahen
    oh, with the tooltype SCALER=none it's much more playable actually. Videos are still a bit slow but it's OK.
  • »19.09.03 - 12:41
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    I was able to play Curse completely to the end!
    (I played it completely from HD...)
    Sometimes it crashed, so save-game would be
    needful :)
    There's is an update of the latest ScummVM,
    which shouldn't have save-load errors....
    good luck!
    bye
    frostwork
  • »19.09.03 - 12:51
