Voodoo5 5500 Mac Edition on G-Rex 1200
    DJBase
    Posts: 745 from 2003/4/6
    I have here a Voodoo5 5500 Mac Edition with PC-BIOS which refuses to work with MorphOS on my G-Rex 1200. The screen just stays black and the system halts somewhere after the reboot. The card works on AmigaOS 3.9. If I replace the Voodoo5 with a Voodoo3, MorphOS boots how it should. Is this a commono problem? Are there any solutions?
  • »16.01.08 - 20:57
    AyoS
    Posts: 410 from 2003/8/13
    is your Voodoo 3 also using the Mac Bios? I used a PC Voodoo5 5500 with My Peg II, but I know that isnt a G-Rex??
  • »17.01.08 - 00:08
    DJBase
    No, the Voddoo3 is a normal PC version. The Voodoo5 works with MorphOS in my Pegasos but it seems not with the G-Rex 1200 for whatever reason.
  • »17.01.08 - 05:16
