MOS Pup with Algor Norway support?
    aPEX
    Posts: 33 from 2007/5/22
    Hello,
    MOS is now booting fine, but I get no network reaction.
    I copied my Miami folder to MOs, set the right assign, copied the norway.device, but after starting Miami I got the error requester "Bad MAC Adress" after that Miami is online, but I can not receive any data...
    OS3.9 and Miami with the same configuration is working fine.
    Anyone with a hint here...? Thank you.
  • »02.10.07 - 10:04
    Crumb
    Posts: 703 from 2003/2/24
    A friend of mine has the same problem :-(
  • »22.10.07 - 10:26
    kempaboy
    Posts: 6 from 2007/2/27
    i'm not familiar whith morway.device but have you tried to query
    device?
    it's in miami's hardware->SANA II parameters->Query device.
    I am using MiamiDX but i think it's same in Miami.
  • »22.10.07 - 13:42
    DJBase
    Posts: 739 from 2003/4/6
    We are waiting since over a year for a fix but....guess what
    Mac mini, PowerPC G4 1.5 GHz, ATI Radeon 9200 64 MB, 1 GB RAM, 80 GB HDD, MorphOS 3.10
    PowerBook, PowerPC G4 1.67 GHz, ATI Radeon 9700 128 MB, 1 GB RAM, 80 GB HDD, MorphOS 3.10
  • »23.10.07 - 22:07
    aPEX
    I tried everything, but the behavior is the strange point. I am receiving some data, but only the first kbs of a homepage, after that it seems to be trying in getting more data, but receiving nothing anymore, it "hang".
    I disabled Trance and set the priority to minus one, but this changed nothing on the behavior.
    I am also in cantact with chris... but you know what happend...
  • »04.11.07 - 16:37
    aPEX
    Very sad that noone will or can help. :-(
  • »08.11.07 - 07:19
