install morphos problem
    Posts: 13 from 2005/5/9
    hello
    i have a problem with install morphos, i open my pegasos then i insert cd with mos 1.4.5 after i type boot /pci/cd boot.img
    on screen show me start and find cd rom and then strat load cd and after some sec stop to load and stuck on load screen :(
    anyone help me?
    i have try and other cd and other version of mos i have the some problem :(
    here a grab to see where have stuck
    http://i167.photobucket.com/albums/u145/bolero2004/DSC00022.jpg
    [ Edited by bolero2004 on 2007/10/11 0:36 ]
    "Nothing Better From A MorphOS/AmigaOS"
    Pegasos G3@600MHz
    MorphOS 1.4.5
    Radeon 7500 128MB
    256MB RAM
    60GB Maxtor HARD DRIVE
    52x CD-ROM
  • »10.10.07 - 23:35
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    You're probably booting with the wrong boot image. If you have a pegasos1, it should be bootpeg1.img or so.
    [ Edited by Fab on 2007/10/11 0:23 ]
  • »11.10.07 - 01:22
    Phantom
    Posts: 381 from 2004/9/7
    Ela re mamalakh, se ksexasa :-P
    Tespa, ekanes auto pou sou eipane? basika de kserw an diaferei to boot apo ton Peg1 se Peg2.
  • »11.10.07 - 13:08
    hello again
    the fab have right i have boot with wrong boot image :)
    now i have other problem , i have make partitions 1 ffs and other 2 sfs and one of this is boot, i have made format on all partitions, i have install successful the morphos but when boot from hd the boot stuck always on morphos logo anyone know something to help me?
    Pegasos G3@600MHz
    MorphOS 1.4.5
    Radeon 7500 128MB
    256MB RAM
    52x CD-ROM
  • »12.10.07 - 01:31
    Jupp3
    Posts: 1193 from 2003/2/24
    That can happen when you have USB massstorage device connected when booting. Remove all of them (and CD's from drives aswell) and try again.
  • »12.10.07 - 05:56
    Daff
    Posts: 247 from 2003/4/5
    bolero2004 : in SCSIConfig, what is the features of your boot partition ? SFS with 512 or 1024 of blocksize ? All partition mounted ? System partition bootable ? FFS partition not bootable ? ...
    [ Edited by Daff on 2007/10/12 12:04 ]
    http://obligement.free.fr
  • »12.10.07 - 12:03
    hello daf
    my boot partition is SFS with 512 blocksize , yes all partition is mounted , partition with boot images is FFS not bootable
    Pegasos G3@600MHz
    MorphOS 1.4.5
    Radeon 7500 128MB
    256MB RAM
    52x CD-ROM
  • »12.10.07 - 12:07
    hello jupp3
    i dont have usb massstorage device connected or any cd on device.
    Pegasos G3@600MHz
    MorphOS 1.4.5
    Radeon 7500 128MB
    256MB RAM
    52x CD-ROM
  • »12.10.07 - 12:10
    walkero
    Posts: 104 from 2006/3/1
    You have to add in the startup-sequence the command
    Wait 1
    after the IPrefs line...
    This is a problem that I have whenever I make a new installation
  • »12.10.07 - 12:30
