Overlay (BVision) and Mos PUP
    zukow
    Posts: 642 from 2005/2/9
    I can't get overlay output from my gfx card (VLAYER=DESTRUCTIVE tooltype is set)
    Any suggestions ?
  • »22.08.07 - 22:08
    Henes
    Posts: 507 from 2003/6/14
    Using which application?
  • »22.08.07 - 22:58
    zukow
    Mplayer:
    Dane:mplayer1.0rc1> mplayer -vo cgx_overlay :Kazik_Celina.avi
    VO: [cgx(overlay)] Hello !. Error opening/initializing the selected video_out (-vo) device.
    Frogger NG - MOS
    "Unable to create a video layer" Window
    Tooltypes in Permedia2 monitor:
    BITMAPCACHE=YES
    PACKED24=NO
    BOOTLOGO=NO
    SCROLLMASK=NO
    VLAYER=DESTRUCTIVE
  • »22.08.07 - 23:27
    Framiga
    Posts: 363 from 2003/7/11
    hummm! once a MOS crew, told me that CVisionPPC supports overlay.
    Where have you got that tooltype?
    Tried here but no way to run MPlayer in overlay mode. (nor FroggerMOS)
  • »24.08.07 - 10:19
    zukow
    overlay mode in bvision is well known fact (and it works on Os3.9).
    from CGX/changes.txt file:
    cgxvideo.library
    Changes for 42.1
    - added support for "destructive" vlayers (CVision/BVisionPPC). This
    type of vlayer can destroy graphics data and requires additional layer
    refresh.
  • »24.08.07 - 15:57
    Framiga
    "overlay mode in bvision is well known fact (and it works on Os3.9)."
    what app/player have you got running in overlay under AmigaOS/BVision?
  • »24.08.07 - 16:43
    zukow
    FroggerNG for PUP/WOS with DISPLAY=VLAYER tooltype set
  • »24.08.07 - 19:57
    Henes
    I am not sure MPlayer supports the special video format(s?) used by the BVision overlay emulation.
    You should try Frogger, AMP and such old players which were tested on a Permedia2.
  • »25.08.07 - 00:08
    Framiga
    ok thanks! under AmigaOS FroggerNG_WOS works in overlay.
    Unfortunately under MOS, don't. (the MOS nor the WOS versions)
  • »25.08.07 - 13:07
