Sound recording?
    Henri
    Posts: 73 from 2003/5/14
    Hello,
    is it possible to record sound from line-in/microphone
    of the Pegasos? How? Which program(s) do I need? AHIRecord
    doesn't work.
    Regards
  • »18.08.03 - 09:46
    Frostwork
    Posts: 302 from 2003/4/18
    Hi, Henri!
    AHIRecord works great here...
  • »18.08.03 - 09:50
    Posts: 261 from 2003/3/13
    Is it possible to record the internal soundoutput also ?? Like, when you're running a AHI app, and record that to a file ?
    Felix.
  • »18.08.03 - 11:56
    Henri
    Okay, AHIRecord works now with Line-In and internal
    CD-input, but not with the microphone.
    Better then nothing, thanks.
    Regards
  • »18.08.03 - 12:53
    So can you start AmigaAMP with a MP3 playing and record that with AhiRec?
  • »18.08.03 - 15:25
    serge
    Posts: 725 from 2003/2/20
    Maybe your micro input is muted on mixer !!!
    Look at wbstartup drawer for mixer tool.
  • »19.08.03 - 08:02
    Ok, but my question remains:
    IS IT possible to Record the output of the Pegasos (example: AmigaAMP playing a MP3) with AhiRecord to a Aiff file ?
    I try'd without any luck so far, When i press record while playing a mp3, AMigaAMP hangs/waits.
    Felix.
  • »19.08.03 - 11:59
    Frostwork
    Hi!
    I didn't try it, but maybe you can start AmigaAMP
    and set the output as filesave and not as PegasosAudio.... (?)
    Good luck!
    frostwork
  • »19.08.03 - 12:16
  • jah
    jah
    Posts: 69 from 2003/3/24
    copy audio:f/44100/c/2/t/signed/b/16/s/55 ram:mysample
    s/55 = record 55 seconds
    this was working with older ahi version...
  • »19.08.03 - 12:24
    Frostwork wrote:
    Hi!
    Good luck!
    frostwork
    I don't need to get the AmigaAMP output sampled :) It was just a example, i need to record the overal AHI soundoutput for my forthcomming program.
    Felix
  • »19.08.03 - 13:07
    Sounds great, ill try that at home :)
  • »19.08.03 - 13:08
    Nah, it doesn't work, it crashes/freezes morphos, and when playing amigaamp same time, it say's audio is in use.. :(((
    Bye,
    Felix.
  • »20.08.03 - 11:39
