Just looking around
Posts: 4 from 2004/4/16
Hello, ...
Due to a problem with my car (no, i am not leaving the pegasos community), i am in need of selling one of my pegasos boxes.
Specs are as follows :
- 2B5 Pegasos 2 motherboard (can handle upto 2GB of ram). Almost new, rarely used.
- 1GB ram module (samsung DDR 400) (if i remember well, didn't open the box to check).
- 160 GB samsung hard drive (again as above, not sure about size, but at least 80 GB in any case).
- DVD writer with dual layer support.
- 128bit radeon 9250 card.
- USB 2.0 NEC 6 port usb card, with connector for front panel usb connectors. (Can trade in a VIA based 4 port card if needed).
- Haupauge PVR 150 low profile TV tuner card (PAL/SECAM) (with hardware mpeg2 encoder)
- black dvine MCE301 case (http://www.ahanix.com/products/mce/mce_301.php), with frontpanel USB, Firewire and parallel connected LCD panel.
- Fanless 450W power supply.
Including the original packaging of the case for easy transport.
It works with a DVI->HDMI connector to connect to your flat panel TV, is pre-loaded with a working Debian GNU/Linux etch system, including support for DVD playback using xine. It may be possible to compile mythtv or further such stuff on it, the sources are included, but i couldn't find time to finish that project.
Price is at 800 Euros + shipping, but i can drive it to a reasonably near place from Strasbourg/France (or vice-versa).
Friendly,
Sven Luther
[ Edited by Sven on 2006/10/12 20:30 ]
[ Edited by Sven on 2006/10/12 20:39 ]
»12.10.06 - 20:19
