Boot only in a particular condition....
    frozen
    Posts: 7 from 2006/9/11
    Hi all.....
    My configuration is:
    A1200 BlizzPPC 603e 200 Mhz Rev1 + Grex + Vodoo3 3000 on PCI Slot 3 + Audio Card ESS Solo-1 on PCI Slot 1 + Realtek 8029as on Slot 5 + PC TV Card on PCI Slot 2....
    For a MorphOs's boot its needed for me that i must remove workbench.library if not after a first reboot i can only have a black screen....
    Any other solution at this kind of problem?
    When i boot without workbench.library i must remove also icon.library because my drawer is unreadable ( i.e.: my fisrt partition is seen as an PNG icon with an interrogative symbol....)
    Thanks in advance for some kind of help...
    When i boot without workbench.library and icon.library i can see old workbench and i must lauch Ambient with my hands ( mouse..... )...
  • »11.09.06 - 22:02
    CLS2086
    Posts: 168 from 2005/8/25
    do you use the fakerom or your kick3.1 ?
    before you started MOS PUP, did you start an another OS3.x with setpach ?
    Which FS and which release did you use to install MOS ? (I used the old unpatched FFS that came from wb3.1)
    Which MOS PUP ISO did you use ?
    Which burning programms did you use ?
    Have you checked the R/W/Exec flag of the files (some burning programms kill them) ?.
    My GREX1200 (2 DMA) is equiped this way :
    Slot 1 : Realtek 8029as
    Slot 2 : ESS
    Slot 3 :"free"
    Slot 4 : TV+FM
    Slot 5 : Voodoo
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »12.09.06 - 09:34
    frozen
    missing information: i have 96 mb ram.....
    No setpatch on my startup-sequence.......
    Only a partition with MorhpOs on DH0....
    I used kick 3.1 and removed fakerom....
    I am using SFS 1.236 and MorphOs 1.4.5 rel 4.....
    Nero Burning Rom for MorphOs CD.....
    Al flags RWED enabled for all files.....
    No MapRom on my BlizzPPC at ESC Menu Flashed to 2.2...
    I have Realtek 8029as 0n Slot 5 and when i can Boot MorphOs without workbench.library and icon.library i can use 68k driver for this device and these works well with D-Link GT604 ADSL Router....( by MiamiDX )
  • »12.09.06 - 10:05
    CLS2086
    look at the research function of the forum :-)
    You'll need older one !
    8029as works for me without trick also with 68k driver and MiamiDX with my Alcatel/Thomson Speedtouch 530 on AOL Network.
    For your 96mb, go to Ebay belgium and look for discoVMax/effy (or get in touch with him on amiga.org), he has a lot of HP 128mb simms modules that work on BPPC.
    Keep the Faith !
  • »12.09.06 - 10:18
    frozen
    i cant find on Aminet version older than 1.236 of SMS....
    Can you give me older one that is ok for you or others?
    For ram module thanks but i have find an American seller:
    http://www.4allmemory.com/index.cfm?fuseaction=search.edo_memory_desktop_72p
    that i think its ok.....
  • »12.09.06 - 10:35
    Chain-Q
    Posts: 347 from 2003/10/12
    That very much sounds like you're trying to use current version of MOS PUP (Rel4) downloadable from the site. Unfortunately a bug leaked into this Release, which prevents it to boot properly on most of the configurations. Try to put back Release 3 version of modules.com1 file, to make it properly boot on your config. If you don't have it, i can send it tou you, or maybe someone else is also able to send it.
    We are planning at least one final update to 1.4.x PowerUP to solve this problem, among others.
    [.Hosting AmigaSpirit.hu.]
  • »12.09.06 - 13:39
    frozen
    I have just tried module1.com from rev. 3 of MorphOs 1.4.5 but with the same black screen after the first reboot avoided only removing workbench.library and icon.library...and using SMS 1.236.....
  • »12.09.06 - 14:27
    CLS2086
    take all the BOOT folder from the rev3, and use a non SFS partition.
    Have you tried to boot first on an overpatch OS3.9 before launching MOS ?
    Keep the Faith !
  • »12.09.06 - 15:41
    frozen
    What do you mean with an overpatch OS3.9?
    I have another Hard Disk for MorphOS with 2 partitions...one for Sys and another for testing software under MorphOs....
  • »12.09.06 - 15:48
    frozen
    FINALLY BOOTING without any problem here......
    As have you said i replaced all BOOT Drawer with the one of MorphOs 1.4.5 Rev3....and with SMS 1.227 ( i'll try 1.236 for testing... ) finally booted with first MorphOs logo and then Ambient screen.....
    Thank for your help.......
  • »12.09.06 - 16:54
    frozen
    I have tried 1.236 and is all OK....no luck with 1.254 after the first reeboot i have a black screen......
    Bye
  • »12.09.06 - 17:55
