Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Aiptek MP3 USB Player on Mos
Lee
# 1
Posts: 70 from 2003/4/9
i bought an MP3 player from Aiptek after plugin
there will displayed on trident follow error message:
Error: massstorage.class Command status failed:nak timeout(10)
Warning: massstorage.class BULK_ONLY_RESET failed:endpoint stall (4)
Can you help?
Is there a possibilty to use this player on MOS?
thanks
MOS rules!
03.08.03
08:26
Targhan
# 2
Posts: 2833 from 2003/2/8
I remember seeing something like this on the mailing list or on the Posiedon website. Do a search here for USB, and you'll find a link in the MWD to the Poseidon mailing list.
Targhan
MorphOS portal?
www.MorphZone.org
03.08.03
08:47
Lee
# 3
thanks
lee
06.08.03
09:22
Jupp3
# 4
Posts: 1193 from 2003/2/24
Try switching "Translate CMD6->CMD10" in prefs
That helped on my CF reader...
Go to Devices page.
Click on the "USB Storage Device"
Click on device listed in list at the bottom on window.
Check that box, I mentioned earlier.
(That did it, for me)
06.08.03
09:56
