miamidx and built-in network port
    catohagen
    Posts: 297 from 2003/5/20
    hi
    im using miamidx and the internal network card in pegasos, and in miami panels, the rate and
    traffic are off/not working...anyone have any clues ?
    And when i query the via_rhinepci.device, miami
    quits ?
    via_rhinepci.device is 50.7
  • »24.07.03 - 01:35
    Posts: 90 from 2003/4/13
    Hard to say ,coz your info is too basic. Sounds like
    "My computer ain't working" , please help me. Forgive me to be straight but I cant help you with this info.
    Mine is working with MiamiDx:-)
    regs
    hgm
  • »24.07.03 - 09:04
    hooligan
    Posts: 1948 from 2003/2/23
    I've got 50.8
  • »24.07.03 - 11:44
    gunne
    Posts: 441 from 2003/2/26
    Hi Cato
    Please send an email, maybe we can sort it out.
    gunne@ggsdata.se
    Have had some other costumers that also had similar problem.
    Best wishes, Gunne
  • »24.07.03 - 13:59
    Posts: 8 from 2003/2/24
    I have problems with Miami + built in nwcard too.
    I got miami and dialup working without much probs,
    but with the rhine.device miami hangs forever looking for IP addresses, and takes the hole
    MUI system with it.
    I have a PhreeBoard (no april) and MOS 1.3.
    Leif
  • »24.07.03 - 16:33
    hooligan
    To put long story short: via_rhine is piece of ####. Put in a Realtek card and be happy.
  • »24.07.03 - 16:54
    <via_rhine is piece of ####>
    A lil off topic , but a Moderator should give his/her opinion moderated. It's just a thought ........:-)
    hgm
  • »24.07.03 - 17:31
    hooligan
    Can't. I battled with the broken driver for a day .. it really is just what I said. After installing Realtek card and drivers for it, everything's worked as it should.
    Also, I have heard older versions works better than the new ones.
  • »24.07.03 - 18:24
    Spidey
    Posts: 568 from 2003/2/24
    Hi hooligan,
    I've got 50.8
    I've got 1.2 :-D(checked with DirOpus)
    Did I miss anything? :-)
    Spidey
  • »24.07.03 - 18:26
    50.5 works fine:-)
    hgm :-)
  • »24.07.03 - 18:37
    Spidey
    Hello cartohagen,
    The Via_Rhine...device of MOS1.3 isn't good.
    On the FTP site you can download another one.
    Further on you have to do the following (just once) after initialisation of the Via...device in MiamiDX:
    - Go to Hardware
    - Select your defined interface and click on Edit
    - Click on the button SANA-II parameters ...
    - Now you have to push the button Query device until you see the right Mac adress in the field Hardware adress (otherwise you'll see a bunch of zero's in this field)
    - Click on Override
    After this you don't have to worry anymore, atleast I don't! :-D
    Good luck,
    Spidey
  • »24.07.03 - 18:37
    catohagen
    ok..i'll check it out.
    >- Go to Hardware
    >- Select your defined interface and click on >Edit
    >- Now you have to push the button Query device >until you see the right Mac adress in the field >Hardware adress (otherwise you'll see a bunch of >zero's in this field)
    >- Click on Override
    did all this also, when i push the query button
    miamidx quits after it finds the mac address, the address is shown aprox. 2 secs, so i repeated query and wrote down numbers, query button again and wrote more numbers and entered them manually :)
    internet and network are working fine, its just
    bugs me about the miami panel not working..
    i've seen other's miami panels working..
  • »24.07.03 - 18:56
    gunne
    Hi
    Choose Miami.mui.panel or gelbes.panel also works fine
    /Gunne
    Best wishes, Gunne
  • »24.07.03 - 20:33
    Posts: 9 from 2003/5/19
    Spidey wrote:
    Hello cartohagen,
    I don't see it on FTP beta 2, where do you fing it ?
    Thanks.
  • »24.07.03 - 21:21
