Startup does no RESET
    Red_Radler
    Posts: 2 from 2005/8/24
    I've installed MorphOS and done the modifications of the startup-sequence.
    Everything fine. But when I reboot from the prepared partition, "startup"
    just loads and then hangs. Independend what reset level is set. I have to
    do the RESET by hand. Then MorphOS boots and everything is fine.
    (As far as I see.)
    Any suggstions about the reset?
    Thanks,
    Christian
  • »25.08.05 - 12:51
    Chain-Q
    Posts: 347 from 2003/10/12
    Only resetlevel 5 works on my CSPPC, and resetlevel 1 on a BPPC i have. That's all the advice i can give. If you specify what kind of hardware do you trying on, maybe more help you could get.
    [.Hosting AmigaSpirit.hu.]
  • »25.08.05 - 13:08
    Red_Radler
    Well, looks like I forgot to test level 5. Works beautifully. Cheers!
  • »25.08.05 - 16:05
