PowerUP Boot Problem
    amigakit
    Posts: 43 from 2005/8/24
    OK rebooted with no startup-sequence
    Cd to the sys:boot directory
    typed Startup command
    It reports that startup is not an executable file
    Can anyone help?
    Many thanks.
    www.amigakit.com - Amiga store
  • »24.08.05 - 23:41
    tokai
    Posts: 1289 from 2003/2/25
    try with to set the script and/or executable flag for the startup script with
    protect SE <startupscript>
    regards,
    tokai
    hope this helps, never used PUP myself, because of lack of CPPC hardware :)
    [ Edited by tokai on 2005/8/25 1:14 ]
  • »25.08.05 - 00:12
    Posts: 2971 from 2003/3/5
    startup is not a script, it's a 68k utility that loads and launches MorphOS.
  • »25.08.05 - 07:45
