Peg I with YDL 4.0 ?
    Posts: 90 from 2003/4/13
    I wonder if YDL 4.0 is for the Peg I.
    Is the Peg I also able to install YDL 4.0? If so......I like to know.
    regs
    hgm
  • »13.10.04 - 09:22
    Posts: 199 from 2004/2/9
    I only can tell you that YDL works with Pegasos 1. No doubts. Unfortunatly I can't tell you how to install it but I'm sure someone will post this info shortly ;-)
  • »13.10.04 - 15:52
    Posts: 8 from 2003/8/28
    http://www.amipeglin.de.vu
    Howto online
  • »14.10.04 - 19:39
    Brumiga
    Posts: 234 from 2004/4/3
    Hello,
    Is the YellowDog distribution localised in french ? I absolutely want to try/use linux in my native language, it will be more comprehensive.
    Brumiga
  • »15.10.04 - 10:13
    brumiga, I'm not sur YDL have a French version but Debian yes. It is available in 23 language :)
  • »15.10.04 - 12:04
    Brumiga
    @Tapero,
    Can you give me a link to download Debian ppc ? I have had a look at Debian's home page but i did not find anything related to ppc.
    An other information please. What do you think about Mandrake ppc ? I have downloaded the 3 iso files, but before burning them on cdr i want to have some opinions about this distribution. Is it easy to install, how to perform install, is it easy to use ?
    Brumiga
  • »15.10.04 - 14:06
    Posts: 11936 from 2003/5/22
    When I try to boot the Image_InstallerSE CD I get the message
    > CD-ROM detected on Device
    > This is not the Image_Installer CD
    > Please, insert the Image_Installer CD in your drive and press enter
    I tried both a CD-RW and a CD-R. Any suggestions?
  • »15.10.04 - 15:01
  • jah
    jah
    Posts: 69 from 2003/3/24
    for debian you should burn
    cdimage.debian.org/cdimage-testing/daily/powerpc/current/sarge-powerpc-netinst.iso
    then you will boot the cd, fill your network parameters and it will
    install all through the net
  • »15.10.04 - 16:08
    brumiga
    Test this
    http://www.debian.org/ports/powerpc/
    Concerning Mandrake, AFAIK it is not ported yet on the Pegasos.
  • »15.10.04 - 16:45
    Posts: 62 from 2004/9/8
    @ DunkleSeele
    http://www.amipeglin.de.vu don't work on Vayager3 or IBrowse...
  • »16.10.04 - 05:19
    oh! my god... oups...
    http://www.amipeglin.de.vu works with IBrowse and not with V3...
    sorry :((
  • »16.10.04 - 06:18
    Posts: 154 from 2003/4/22
    @tapero:
    http://www.mandrakelinux.com/en/ftp.php3
    Mandrake 9.1 is ported on PowerPC so it works on Pegasos.
    Bye
  • »16.10.04 - 10:40
    Brumiga
    @The french users,
    Could it be possible to continue this conversation and these explanations with you, or one of you, in private and in french ? Mail me at bruno.flamme[@]wanadoo.fr. Remove the [ ].
    Brumiga
  • »16.10.04 - 14:02
    There is also (unofficial?) Mandrake 10.1 for PPC.
  • »16.10.04 - 17:56
    My problem is solved. But I have a new one: the bunzip command cannot be found...
  • »16.10.04 - 19:03
    bzip2 -d archiv.tar.bz2
  • »16.10.04 - 19:33
    This posting was done with Mozilla 1.7.2 on YDL 4.0 on Pegasos I :-D
  • »18.10.04 - 01:24
    Now there's *official* Mandrake 10.1 for PPC :-)
    http://archives.mandrakelinux.com/cooker-ppc/2004-10/msg00057.php
  • »26.10.04 - 19:49
    <This posting was done with Mozilla 1.7.2 on YDL 4.0 on Pegasos I :-D >
    Nicely done , but how about java with LinuxPPC??
    I admit that my java is NOT working. Got somewhere a message that java 1.3.1 and Mozilla 1.7.2 dont match
    gggrrrrrrrrrrrrrrr
    regs
    hgm
  • »26.10.04 - 20:13
    http://www6.software.ibm.com/dl/lxdk/lxdk-p
    Didn't manage to download though.
  • »27.10.04 - 12:00
    I was able to download now, but:
    http://lists.terrasoftsolutions.com/pipermail/yellowdog-general/2004-October/016080.html
  • »28.10.04 - 14:26
