Peg1 + SB Live LS + Radeon 9000 = Success
    Posts: 13 from 2004/3/19
    A few months ago I reported that my Peg1 was having screen corruption when booting with both the Radeon 9000 and it's new 20GB hard disk. I then put the Voodoo 3300 back in, which fixed the problem but rendered the OF messages invisible. Well today I put a SB Live! LS 5.1 soundcard into the machine, got it working under MorphOS 1.4.2, and the latest AHI drivers, then decided to try it with the Radeon 9000 installed, and it works perfectly! All of this certainly points to PCI timing issues on the Peg1.
    I viewed one of Shania Twain's music videos on DVD using MPlayer with AHI set to use the SB Live at Hi-Fi 16bit stereo++ and everything seemed to work like a charm, including Livemixer.
    Jeff
    Pegasos I G3/600
    MorphOS 1.4.2
    128MB RAM
    Toshiba DVD-ROM
    20GB WDC Hard Disk
    Radeon 9000
  • »09.10.04 - 17:42
