Mplayer question
    BigGun
    Posts: 150 from 2004/6/18
    I use Mplayer for playing Video and DVD content.
    Usually the movies are widescreen and not designed for the 4/3 display ratio aspect of my monitor and so they have black bars on top and bottom.
    Often the black bar are quite big. I would prefer to cut of a bit on the left and right of the video to get smaller black bars.
    Is there a way to zoom into the video so I can make better usage of my screen?
    Cheers
    Gunnar
  • »27.06.04 - 09:15
    tokai
    Posts: 1289 from 2003/2/25
    yes. there is a way.
    When you know the real (pixel) size of your videostream then you can use "-vop crop=w:h:x:y" parameter to 'zoom in' to the video.
    e.g.:
    work:gfx/mplayer/> MPlayer "movie:sac/ep01.avi" -vop crop=400:200:10:10
    400:200 is the size (width:height) and 10:10 is the offset (x:y).
    (same works with mencoder too)
    regards,
    tokai
  • »27.06.04 - 11:30
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP on 2011/3/12 7:42 ]
    Pegasos2 G3, 512 megs RAM
  • »27.06.04 - 13:00
    BigGun
    Thanks Tokia,
    The video topic brings me to another question:
    Is there a recomandable tool for MOS to do DVD backups ?
    Either something DVD -> CD (dixv)
    or DVD -> DVD (with maybe cutting/remastering possiblies to make the DVD fit on empty one)
    Cheers
    Gunnar
  • »27.06.04 - 16:43
    ChatDEau
    Posts: 248 from 2003/4/4
    Hello BigGun!
    I'm working on a small script that'll make DVD -> DivX encoding an easy task.
    Will be on MorphZone really soon ;)
    Fred
  • »27.06.04 - 21:46
    magnetic
    Posts: 2129 from 2003/3/1
    ChatDeau
    That will be fantastic! Thank you :-D
    magnetic
  • »27.06.04 - 21:58
    Wishmaster
    Posts: 342 from 2003/6/29
    For best qualitz use 2pass encoding and some of the following options to increase qualitz further. v4mv:trell:mdb=2 and -oac copy to put all audio streams into the avi, -aid xxx to select a specific one.
    If you want to encode audio to mp3 you must add -mc 0 otherwise a/v will get out of sync.
    Pegasos PPC
  • »28.06.04 - 13:52
