IoctlSocket freeze
    Tcheko
    Posts: 510 from 2003/2/25
    I experience a trouble with IoctlSocket call.
    I create a simple socket :
    sock = socket(AF_INET, SOCK_STREAM, 0);
    IoctlSocket(sock, FIONBIO, &val);
    It freezes on IoctlSocket call.
    I use Dev bundle from genesi. Compiling with ixemul.
    Any advice?
    Thanks!
  • »27.05.04 - 01:39
    Tcheko
    I have asked as well on mdc ;).
  • »27.05.04 - 11:57
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    With libnix it should work, i've done it (provided you opened bsdsocket.library).
    with ixemul, if it really freezes, try fcntl() or ioctl() instead of ioctlsocket().
  • »27.05.04 - 12:06
    Neko
    Posts: 301 from 2003/2/24
    Try not to use MorphOS library calls inside ixemul applications :)
    IoctlSocket() is in bsdsocket.library
    for ixemul, ioctl() is in ixnet.library
    Obviously you can't mix them. Just use ioctl() if you're using ixemul, and IoctlSocket() if you're using libnix.
    Neko
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »27.05.04 - 12:15
    Tcheko
    Hello,
    Issue solved.
    Mixing calls between ixemul and bsdsocket is not a good practice ;)
    Thanks for help.
    Regards.
  • »29.05.04 - 21:57
