CONFIGURARE MIAMIDX SU MORPHOS
    Posts: 3 from 2004/5/14
    Hi !
    Thankyou for your help!
    I have done all i can (I think) to get a working net!
    The only thing is that i dont use a dhcp configuration...
    I use a static ip with a gateway to my router...
    I had set also primary and secondary DNS but nothing...
    When i push online button on interfaces the net gooes online even if cable is disconnected.....
    Maybe an hardware problem?
    I use rhinevia.device ....
    What I have to do?
    I use a linux x86 flawless...
    Where is the problem?
  • »17.05.04 - 08:58
    tokai
    Posts: 1289 from 2003/2/25
    hmm... dunno what's wrong in your install. But I'm using a static-IP connection (with router/switch) too and it works well.
    I made you a few screenshots and marked the AFAIR important parts. Hope they can help you. Oh.. and sorry that everything is ghosted, but i didn't wanted to go offline for the screenshots. :-D
    screenshot 1
    Screenshot 2
    Screenshot 3
    Screenshot 4
    regards,
    tokai
  • »17.05.04 - 09:46
    Elektro
    Posts: 202 from 2004/2/3
    @Tokay
    This configuration can be used also to make a LAN with Peg and PC?
    I'd like to share the internet connection of my PC with my Peggy!
    Tnx!
  • »17.05.04 - 12:00
