Future-proof addresses
    Samurai_Crow
    Posts: 198 from 2009/12/10
    Cross-post from the AmigaOS 3 forum:
    Greetings! It just occurred to me that message port handles being addresses are always on even numbers due to alignment constraints. After looking at Gunnar von Boehn's additions to the 68080 and SAGA softcores, it occurred to me that using bit zero as a flag could be used to switch to a different message port encoding such as an enumeration. Once that is no longer address constrained, it could allow 64-bit addressing both on AmigaOS 3+ and ApolloOS. If MorphOS follows suit, great!
  • »19.07.25 - 11:37
    Piru
    Posts: 624 from 2003/2/24
    What was the problem you try to solve with 64-bit messageports? This sounds like a solution looking for a problem.
    Using some bits of addresses for "magic" information is asking for trouble. Just ask how easy it's to run AmigaBASIC on Amigas with 32-bit memory. Or how convenient it is that AllocEntry() uses bit 31 to indicate error condition.
    Also, this isn't a generic solution to encode 64-bit addresses as many addresses can be odd.
    If you go 64-bit do it properly with real 64-bit addressing everywhere. 32-bit legacy stuff can be run in a runtime environment.
    No, MorphOS will not adopt stupid concepts.
  • »19.07.25 - 13:15
    Georg
    Posts: 129 from 2004/4/7
    So the "boxes = evil" era is over?
  • »19.07.25 - 15:17
    Samurai_Crow
    The problems associated with having addresses used for handles of message ports also include lack of memory protection. Being able to map 32 bit functions into a 64 bit address space for backward compatibility is mainly for legacy code. A new message port structure for 64-bit addressing would be preferred but the old ones would still need to be kept around as long as Trance or any other 32-bit architecture stuff needs kept around. Alignment from the AllocMem() allocator has always been guaranteed to be aligned to 4-byte increments (sizeof APTR). Unless message ports don't need that alignment, bit 0 and 1 should always be 0 but we don't need to get too crazy.
    As for bit 31 being an error code in one function, remapping that to be the sign bit of whatever word-size is in use would at least have an equivalence, if it is needed at all.
  • »21.07.25 - 11:15
    Samurai_Crow
    Would a transition to a "message.device" be preferred? Send message and reply message existing code would become legacy in such an instance.
  • »21.07.25 - 11:53
    Posts: 2584 from 2003/2/24
    @Georg
    A box? What a weird idea...
    @Ninja-Pigeon
    Sounds like a half measure that doesn't really fix anything.
  • »21.07.25 - 13:06
    Piru
    I still don't understand the problem you're trying to solve here.
  • »21.07.25 - 16:17
    Samurai_Crow
    Every time I've tried to figure out ways to implement solutions for SMP and memory protection, I've been told that the way that handles using addresses, that enforced flat memory models, were non-conducive to solutions in those cases and unless that was changed in some way, they would continue to be unsolvable. This would be a light at the end of the tunnel for those previously "unsolvable" problems.
  • »21.07.25 - 18:04
    Piru
    No, it would not.
    I think you've misunderstood something, or someone has been explaining things badly. Being restricted to 4GB address space doesn't exclude SMP or memory protection. There are far bigger issues at the API/ABI level that block those, and there is no way around them (this is why there is no working SMP or memory protection). Use of bit 0 to have "64-bit messages ports" (whatever that means in practice) or introducing some exec message.device is not going to fix any of those issues.
    Either way, if you introduce a new messaging system, you will be breaking the existing ABI. At that point, it doesn't really make sense to drag along the current concepts. A clean break would make much more sense, and then you could bake in SMP and memory protection from the start.
    Note that this is not any kind of statement about MorphOS in specific nor does it specify any paths MorphOS might or might not take.
  • »21.07.25 - 21:34
    Posts: 3337 from 2003/3/5
    Samurai_Crow wrote:
    Every time I've tried to figure out ways to implement solutions for SMP and memory protection...
    I think the only way you can convince us is by showing a working demo. Take AROS' source code and try to make it all work. Good luck.
  • »22.07.25 - 10:11
    Samurai_Crow
    Nobody tests AROS ABI v1 any more. They're so hung up on ABI v0 they don't care about 64-bits and AROS SMP.
    Anyway, I'll go back to minding my own business with EEC (my fork of ECX) and seeing if I can get the bugs worked out of that first. If I can implement QBE as backend.library, AmigaE may get a new lease on life.
    Ciao!
  • »22.07.25 - 17:04
    Maybe because pretty much everybody came to the conclusion that it would lead nowhere.
    For systems that need binary compatibility (read MorphOS, OS4 AROS_68k) it was never an option.
    Even going just for source code compatibility would be an issue as so much old stuff uses datatypes that won't just automatically adapt and expand to 64bits addressing.
    And you still wouldn't have tackled anything beyond increasing the amount of useable RAM.
    So yes to fix all that you would need completely new APIs.
    This could be done by running the "classic" portion of the OS boxed in with a modern OS calling the shoots, or you could have a minimal modern OS running on extra cores/RAM that can be accessed with a limited API (think PowerUP, the OG x86 modules in Amitlhon or even Janus.library for those old bridgeboard).
  • »22.07.25 - 17:40
    Samurai_Crow
    Haiku with hosted AROS would be interesting but only if it supports pure, resident, reentrant code. Otherwise, just ditch AROS. At least Haiku is POSIX compliant enough to port Linux code more easily. I just wish that the Haiku users would get over their partiality of "native code" even though old BeOS source code is nearly unobtainable and suffers the same ills as AROS ABI v0 when running on 32-bit systems.
  • »23.07.25 - 01:34
    Posts: 2220 from 2003/2/24
    Although a hosted AROS was just plain horrible on Linux, at least couple of years ago. Half of the things crashed or did work in an unexpected way. It was just impossible to do even minimal testing on it and I had to move to a full emulator to get a working AROS test environment.
  • »23.07.25 - 03:48
    Georg
    Hosted AROS is a normal Linux program so if AROS components themselves or a program run under it does something bad (like access bad address) it will much more easily show up as crash because of Linux mem protection. Whereas in native AROS (like in AOS68k or MOS?) because of none at all or less mem protection such bugs more easily go undetected and the OS and programs often keep on running as if nothing happened.
    But debugging with AROS hosted is very easy and fast because you can run it as a whole in "gdb" and the whole OS with all tasks/libs system/user/whatever can be debugged symbolically.
    (gdb) bt
    #0 Graphics_51_RectFill (rp=0xe8d634d4, xMin=0, yMin=0, xMax=2559, yMax=18, GfxBase=0xe8854980) at /home/georg/aros/arosdeadwoodaltabiv0/AROS/rom/graphics/./rectfill.c:63
    #1 0xe77b7c77 in __inline_Graphics_RectFill (__arg1=0xe8d634d4, __arg2=0, __arg3=0, __arg4=2559, __arg5=18, __GfxBase=0xe8854980)
    at /home/georg/aros/arosdeadwoodaltabiv0/alt-abiv0-linux-i386-d/bin/linux-i386/AROS/Development/include/inline/graphics.h:778
    #2 0xe77b9eec in RenderMenuBar (mhd=0xe88a87a0, IntuitionBase=0xe8869ee0) at /home/georg/aros/arosdeadwoodaltabiv0/AROS/rom/intuition/./menutask.c:984
    #3 0xe77b9c52 in MakeMenuBarWin (mhd=0xe88a87a0, IntuitionBase=0xe8869ee0) at /home/georg/aros/arosdeadwoodaltabiv0/AROS/rom/intuition/./menutask.c:925
    #4 0xe77b7fad in DefaultMenuHandler (taskparams=0xffffc8d8) at /home/georg/aros/arosdeadwoodaltabiv0/AROS/rom/intuition/./menutask.c:167
    #5 0xe7680270 in __inline_Exec_InitSemaphore (__arg1=0x0, __SysBase=0x0)
    at /home/georg/aros/arosdeadwoodaltabiv0/alt-abiv0-linux-i386-d/bin/linux-i386/gen/rom/exec/exec/include/inline/exec.h:1321
    #6 0xffffc8d8 in ?? ()
    (gdb) print rp
    $13 = (struct RastPort *) 0xe8d634d4
    (gdb) print *rp
    $14 = {Layer = 0xe8d63420, BitMap = 0xe90189d0, AreaPtrn = 0x0, TmpRas = 0x0, AreaInfo = 0x0, GelsInfo = 0x0, Mask = 255 '377', FgPen = 0 '00', BgPen = 0 '00',
    AOlPen = -1 '377', DrawMode = 0 '00', AreaPtSz = 0 '00', linpatcnt = 15 '17', dummy = 0 '00', Flags = 0, LinePtrn = 65535, cp_x = 0, cp_y = 0,
    minterms = "00000000000000", PenWidth = 0, PenHeight = 0, Font = 0xe8a31b10, AlgoStyle = 0 '00', TxFlags = 0 '00', TxHeight = 13, TxWidth = 7, TxBaseline = 9,
    TxSpacing = 0, RP_User = 0x0, RP_Extra = 0x0, longreserved = {0, 0, 0, 0, 0, 0}, reserved = "00"}
    (gdb)
    It does not matter if something is in Forbid state, or deadlock, or whatever. CTRL-Z gets you in the debugger. You can show backtrace of running Exec tasks or any other task. You can reboot in fraction of a second. Even simple method like having tons of debug output with kprintf is extremely fast and most of the time will not slow things much at all. You can filter away some output with "grep" if not. You can use hardware watchpoints (tell gdb to interrupt when a certain mem address was written/read without slowdown).
  • »23.07.25 - 05:02
  • o1i
    Posts: 54 from 2003/2/25
    I really don't get all those bad comments about AROS. MorphOS would have needed much longer to get away from requiring os3 libraries back then. Abi v1 runs circles around morphos when it comes to gcc support, available libraries and development tools. And there at least is smp and 64bit support, nothing of which I have seen on MorphOS. MorphOS is better in other ways, better usability, better tested.
    So why all that bashing? People are working in their spare time, enjoy it and letting you use their results. How bad can that be?
    And it is not true, nobody tests v1. Guess some apollos and a500gs users do. And I test x86 64 bit and love to develop for it.  ;-).
  • »29.07.25 - 07:40
    Nadir
    Posts: 178 from 2003/3/17
    Just out of curiosity, what's so much more advanced about aros' gcc support, libraries and development tools? Both OSs have their strenghts and weaknesses of course but the MorphOS SDK is kept quite up to date in recent years, particularly when it comes to gcc, binutils and so on. MorphOS also comes with a quite advanced IDE that I think is more complete than anything available on either AROS or OS4 (I'm biased, I know :-)
    I would argue that the major weakness MorphOS has when it comes to its development infrastructure is documentation, but to some extent that weakness is probably shared with AROS.
  • »29.07.25 - 12:08
