Posts: 1518 from 2012/11/10
There are plenty of
UJ-85J (IDE) as well as other Apple/Matsushita (Panasonic) superdrives available via the usual online stores ATM, and they are cheap. So, it's worthwhile keeping a spare for such an eventuality, as they are easy to replace and a direct replacement, and actually an enhancement, to the standard CDRW-DVD-ROM (Combo) or CDRW-DVDRW drives that Apple fitted as Superdrives back when the G4/G5 hardware was new. Not as plentiful a supply to replace the IDE DVDRW drives in Power Macintosh's, but probably any IDE DVDRW drive will do just fine. I haven't had to replace mine, and I've a few spares from such hardware anyway, as well as some other IDE DVDRW drives.
After this amount of time it is often just the read/write lens that will have got dirty/dusty which is enough to stop it from reading/writing, but with some careful cleaning they usually spring back into working life.
You can use an external USB CD/DVD drive with the Dual-boot Mac side of the Apple hardware, but using them with MorphOS has still not been properly addressed, I wish I could say that it had.
