Flowstudio and Templates
    GMKai
    Posts: 256 from 2003/4/7
    I am using Flowstudio to create Hollywood-Scripts.
    Flowstudio knows some Templates to assist with typing/coding.
    The guide of Flowstudio mentions Templates, but the menu leaves these out?
    Is there something to configure/edit? To make existing templates reachable?
  • »14.10.24 - 13:11
    igracki
    Posts: 421 from 2003/2/24
    Some years ago I wrote some scripts for FlowStudio to help programming in Hollywood.
    FlowStudioHollywoodScripts
    You can try, if you want.
  • »14.10.24 - 16:19
    GMKai
    Thank you. That seems helpful.
    Besides that I found the entry in question:
    "Ansicht/Abkürzungen", might translate to
    "View/Shortcuts".
    that entry was invisible...
  • »15.10.24 - 12:08
