Native library question
    alfie
    Posts: 96 from 2005/3/25
    I am in a native library. At offset -30 there is a function foo that:
    - receives one argument in A0
    - returns 2 results in D0 and A0
    Is the following code correct?
    funcTable[] =
    (APTR)FUNCARRAY_32BIT_RESTORE_NATIVE,
    (APTR)foo,
    (APTR)-1,
    void
    foo(void)
    ULONG arg = REG_A0;
    ULONG res_d0, res_a0;
    ULONG d[8], a[8];
    int i;
    for (i = 1; i<8; i++) {
    d[i] = MyEmulHandle->Dn[i];
    a[i] = MyEmulHandle->An[i];
    MyEmulHandle->Dn[i] = d[i];
    MyEmulHandle->An[i] = a[i];
    REG_D0 = res_d0;
    REG_A0 = res_a0;
    The above works, but I feel like there must be a "more elegant" solution.
  • »31.05.24 - 11:46
    Tcheko
    Posts: 540 from 2003/2/25
    funcTable[] =
    (APTR)foo,
    (APTR)-1,
    void
    foo(void)
    ULONG arg = REG_A0;
    ULONG d[8], a[8];
    int i;
    REG_D0 = res_d0;
    REG_A0 = res_a0;
    This function likely returns random values from stack in D0 and A0. The copy from emul regs are doing nothing too, can probably be removed without harm.
  • »01.06.24 - 00:16
    alfie
    OK thanks, but the solution is ?
    PS
    That doesn't return random values; the library works in a very complex scenario without problems. If I remove the savings, the system freezes.
  • »01.06.24 - 03:58
    Posts: 2452 from 2003/2/24
    This is a function in a library, so yeah that is needed at least for as long as it uses 68k based calling.
    Just looked up what I did in my LUA MUI/ABox wrapper and it looks the same and AFAIR I nicked that from some example code so this seems the way to go.
  • »01.06.24 - 04:16
    Tcheko
    PS
    Missed the ... between the loops. You're doing other stuff in. My bad.
    Still, I am a bit puzzled. I never had to mess with emulreg handle directly in my 68k compatible library (camd.library for instance).
    Using FUNCARRAY_32BIT_NATIVE is just good enough for most libraries if the compatibility with 68k binary is needed afaik.
    Library function looks like
    VOID LIB_DummyFunc()
    struct LibBase *Base = REG_A6;
    APTR arg0 = REG_A0; // whatever the function needs as argument
    ULONG arg1 = REG_D0;
    [[ do interesting stuff ]]
    REG_D0 = result;
    As you can see, no emul context saving needed.
    Why are you using FUNCARRAY_RESTORE_NATIVE instead of the more common FUNCARRAY_32BIT_NATIVE?
  • »01.06.24 - 08:15
    alfie
    The function foo must return an error code in R0 and a STRPTR in A0 if R0 is 0.
    FUNCARRAY_32BIT_NATIVE would restore A0.
    The right one seemed to be FUNCARRAY_32BIT_RESTORE_NATIVE and it works, but I am not truly sure...
    [ Edited by alfie 01.06.2024 - 13:46 ]
  • »01.06.24 - 09:45
    Piru
    Posts: 595 from 2003/2/24
    I would use FUNCARRAY_32BIT_D0D1A0A1SR_NATIVE in this case.
    Place the desired A0 value to REG_A0 (*) before final return. You don't need to worry about D1, A1 or SR as they're generally undefined after function calls anyway (well except that REG_SR supervisor side flags must not change naturally).
    *) REG_A0 is a #define to MyEmulHandle->An[0] normally.
    [ Edited by Piru 01.06.2024 - 18:29 ]
  • »01.06.24 - 13:28
    alfie
    Thanks, it is actually "more elegant" :)
  • »02.06.24 - 21:29
