PowerMac G5 A1047 Video Out of Range
    Derek
    Posts: 3 from 2023/1/10
    I have a PowerMac A1047 fitted with a ATI Radeon 9600XT 128MB Graphics card.
    When I boot from MorphOS CD-ROM disk, the VGA monitor goes out of range and says display not supported.
    What is the video resolution of installation MorphOS?
    I have a MacMini G4 1.25Ghz, installed with MorphOS, which works at 640x480 on the same monitor.
    Regards,
    Derek
  • »08.03.24 - 10:33
    Zetec-s
    Posts: 194 from 2008/7/10
    If you press CTRL during booting up this should force MorphOS to use a resolution of 1025x786 which most displays can show.
  • »08.03.24 - 23:13
    Posts: 12081 from 2003/5/22
    > 1025x786
    1024×768 ;-)
  • »08.03.24 - 23:28
    Derek
    Thank you for the information, I tried pressing the CTRL key on MorphOS boot up and it the video changed from 1024x768@75 to 1024x768@60
    I have installed MorphOS to the 160Gb Hard drive, and all is working, was able to connect to my Network Shares on a Linux server.
    I will have re-read the re-read the documentation again.
    [ Edited by Derek 09.03.2024 - 19:05 ]
    Regards,
    Derek
  • »09.03.24 - 11:37
