Posts: 12081 from 2003/5/22
> Good to know on the old Yikes! model. Kinda surprised it doesn't,
> because this is an AGP model
If it's really AGP it should be supported. But then, it's not the Yikes. According to several sources, the Yikes model is the PowerMac1,2, which doesn't have AGP slots:
https://en.wikipedia.org/wiki/Power_Mac_G4#Graphite_model_variationshttps://lowendmac.com/1999/power-mac-g4-yikes/https://lowendmac.com/2014/yikes-power-mac-g4-a-second-class-mac/https://everymac.com/systems/apple/powermac_g4/specs/powermac_g4_350.htmlMany years back you said Sawtooth was the first to come with AGP:
https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4368&forum=11&start=22 (#23)
> These old machines can also hold over a gig of RAM
According to the above-linked Wikipedia article, of the 1st PowerMac G4 generation, the Yikes (PowerMac1,2) and the early Sawtooth (PowerMac3,1) models support up to 1 GiB, whereas the later Sawtooth models and the Gigabit Ethernet (PowerMac3,3) model support up to 2 GiB. Interestingly, the 2nd generation (Digital Audio and Quicksilver; aka PowerMac3,4 and PowerMac3,5) regressed to 1.5 GiB maximum, which was increased back to 2 GiB with the 3rd generation (MDD and FW800; aka PowerMac 3,6).
> some of the original PPC OS work was done on hardware
> that involved reflashed Sonnet G3 and 4 accelerators
Yeah,
that one with two ZIF sockets.
> so the protocol of that big square mobo connector shouldn't
> be too much a mystery.
Yes, I don't think the ZIF connector on the Yikes mainboard is the reason for missing Yikes support in MorphOS.
