Last linux for pegasos2
    Doraemon
    Posts: 137 from 2003/7/1
    Hello.
    I've tryed to install a debian ppc netinst without luck.
    The are any linux ppc distro thats actualy updated for ppc that works fine in a peg2?
    The pegasos book its really outdated and I can't find information about this
    Thanks for all
  • »18.07.23 - 17:56
    Cego
    Posts: 681 from 2006/5/28
    Jessie works fine
  • »18.07.23 - 17:58
    Doraemon
    I've tryed the debian 8.11 netinst but the instaler can't find the internet repositories to download all the required.
    I've tryed a lot of mirrors in the installer without luck
    Newer versions 9 , 10, 11 , et do not have /intall/pegasos file in the netinst iso
  • »18.07.23 - 18:12
    Cego
    Jessie got dropped and repos are just available via archive mirror.
    Take the Install DVD and after install change the /etc/apt/sources.list
    Add these and you should be fine.
    deb http://archive.debian.org/debian/ jessie main non-free contrib
    deb-src http://archive.debian.org/debian/ jessie main non-free contrib
    deb http://archive.debian.org/debian-security/ jessie/updates main non-free contrib
    deb-src http://archive.debian.org/debian-security/ jessie/updates main non-free contrib
    [ Edited by Cego 18.07.2023 - 20:00 ]
  • »18.07.23 - 18:59
