New version of MorphOS Pagestream!
    BatteMan
    Posts: 275 from 2003/2/24
    I'm speechless !
    Thx ! Very much !
  • »30.12.22 - 14:02
    tolkien
    Posts: 474 from 2013/5/29
    Oh man! First time I win something in my life hehehe. I can only say thanks so much.
  • »30.12.22 - 15:23
    discreetfx
    Posts: 380 from 2003/7/26
    Enjoy the great software guys. MorphOS needs more excellent software just like this. At least DTP is well covered now as is web browsing.
    [ Edited by discreetfx 30.12.2022 - 10:26 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »30.12.22 - 17:23
    Primax
    Posts: 89 from 2021/7/2
    Thank you very much! :)
    What a wonderful surprise! :)
    [ Editiert durch Primax 30.12.2022 - 20:24 ]
    AmigaOne X5000 @ 2GHz / 4GB RAM / Radeon X1650 / AmigaOS 4.1 Final Edition / MorphOS 3.17
    Amiga1200 / Blizzard 1230 IV / 128 MB RAM / AmigaOS 3.9
  • »30.12.22 - 20:23
    BatteMan
    Just receive the confirmation mail and the licence for the pro version has been added to my account ! What ending for 2k22 !
    Thx Bill, thx Deron, thx Frank, Christoph and everybody involved !
  • »30.12.22 - 21:10
  • IKE
    IKE
    Posts: 146 from 2009/11/7
    I don't really do DTP but I bought a license to support these MorphOS developers. Looks good so far, I'll have to play around with it some more!
    IKE
  • »31.12.22 - 00:15
    discreetfx
    All the winners should have their PageStream 5.1 Pro licensing information by now. Enjoy your new DTP software and have a wonderful 2023. Keep a lookout for future DiscreetFX giveaways and contests in 2023.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »01.01.23 - 15:58
    Posts: 2039 from 2003/6/4
    I like your initiative! How about a give away for content providers.
    I think we need more content (progams, tutorials, youtube videos, etc.) and while it's mostly due to internal motivation some incentive could elicitate a little additional motivation.
    http://www.via-altera.de
  • »01.01.23 - 16:59
    discreetfx
    Great idea, we will consider it.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »01.01.23 - 17:09
    _coliN_
    Posts: 65 from 2003/4/30
    Hello!
    Are the scripts in new Pagestream working, like CurveText?
    Or is my installation faulty?
    It makes a lot of fun working with the new version, now this feature is still missing...
    Thanks!
  • »11.01.23 - 16:57
    matt3
    Posts: 542 from 2004/2/10
    Having a blast using this!
    Can you print a document to a printer?
  • »11.01.23 - 20:14
    NewSense
    Posts: 1340 from 2012/11/10
    matt3 wrote: Having a blast using this!
    Good got hear you're enjoying using it. :-)
    matt3 wrote: Can you print a document to a printer?
    Of course you can. What type of printer do you have? Is it an inkjet or a laser or some other type. Also, do you know if it supports PostScript or PCL printing? :-?
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.17,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5.
  • »12.01.23 - 01:37
    matt3
    Really done some nice work with it!
    I have a HP Deskjet 6127. It prints fine with stuff like final writer, but when I go to print in PS it says Bitmap or PostScript Printer and doesn't have ability to print.
  • »12.01.23 - 21:39
    NewSense
    matt3 wrote: Really done some nice work with it!
    You can of course save a document as a PDF, and then print it out as you normally would, but if you've used PNGs in the file then they may not print out as expected, so it's better to use TIFF currently - the PNG 'thing' (bug) has been reported. ;-)
    matt3 wrote: I have a HP Deskjet 6127. It prints fine with stuff like final writer, but when I go to print in PS it says Bitmap or PostScript Printer and doesn't have ability to print.
    I had a quick look at your printer spec and it seems it is a raster printer, so it probably came with a PCL printer driver, and is NOT PostScript capable. However, you can use Ghostscript or Turboprint's PS option to print out as though it were a PostScript file, or hopefully you can just find a compatible HP PCL5 desktop inkjet printer driver in Turboprint that will do what you need more simply, though the printout resolution may be noticeably/slightly lower than PostScript. 8-)
  • »13.01.23 - 01:08
    matt3
    Ok, almost got this working thanks to your help, thank you!
    I have a turbo print driver specifically for this printer, and I went to the post script tab and reviewed the following:
    Ghostscript/bin:GS -sDEVICE=turboprint -q
    It can't find the turboprint device.
  • »13.01.23 - 02:32
    NewSense
    matt3 wrote: Ok, almost got this working thanks to your help, thank you!
    No problem, glad to be able to help you out of the situation, and get the benefit of printing to your HP 6217 inkjet printer. 8-)
    matt3 wrote: I have a turbo print driver specifically for this printer, and I went to the post script tab and reviewed the following: Ghostscript/bin:GS -sDEVICE=turboprint -q . . . It can't find the turboprint device.
    So, the Ghostscript application has its own DEVICE, namely GS: which you quote in the option Device in the PostScript printer option of the same name. Likewise the Turboprint device driver for that application also has it's own device, that being PS:. You can of course just use the Bitmap File option instead of the PostScript File option in the PageStream Printer Setup (Preferences) and use the Turboprint printer driver to print out the file that way, or as I said you can save the file as a PDF and then print it as you would any other PDF that you print out with your MorphOS system and your printer.
    I hope this has answered your current problem, and enabled you to print out whatever you create with PageStream. 8-D
  • »13.01.23 - 03:47
