Connecting to VNCServer problem
    gevik
    Posts: 16 from 2022/11/29
    I am unable to connect to the VNCserver from an Intel Mac. I don't know if this is a client or a server problem.
    When I connect to the MorphOS machine with my Intel Mac, I get the password dialog and after a second or two I get "connection closed unexpectedly"
    Anyone seen this before?
    Thanx
  • »14.12.22 - 22:28
    Posts: 2978 from 2003/3/5
    What client are you using on the Mac side? Apple's built-in VNC doesn't really follow the protocol.
  • »15.12.22 - 19:56
    gevik
    I downloaded the standard VNC viewer from RealVNC
  • »15.12.22 - 23:57
    I was able to connect to the MorphOS VNC server with no issues. Did you have a display hooked up to the MorphOS machine while attempting to connect? It will prompt you to accept an incoming connection - otherwise, you may set it up in advance in the Access list tab.
  • »18.12.22 - 19:03
