IGame 2.2.0 is not working
    gothor
    Posts: 32 from 2011/4/6
    IGames is not working correctly for me. I see the main window, but not the menus to create a library. I have a G5 with Morphos 3.17. Any idea?
    Thx
    Christoph
  • »18.11.22 - 08:00
    kriz
    Posts: 309 from 2005/10/18
    Just tried it here also, installed the mos version but i don`t get any window to open at all ...
    Check also here, seems 68k version still works under mos:
    https://www.morphos-storage.net/?id=1822538
    [ Edited by kriz 18.11.2022 - 09:06 ]
  • »18.11.22 - 09:04
    gothor
    Thx. the 68k Version is working fine and i can use the MenĂ¼s, but the game did nort starting. mhmm
    [ Editiert durch gothor 18.11.2022 - 10:23 ]
  • »18.11.22 - 10:20
    kriz
    I was missing the texteditor.mcc files, now the 68k version works here.. Just tried to add a game and it worked atleast ..
    [ Edited by kriz 18.11.2022 - 11:15 ]
  • »18.11.22 - 11:14
