Connect old 5GB firewire400 iPod
    Elowan
    Posts: 214 from 2011/4/18
    hi there,
    I got an old iPod (the 1st model, 5GB fw) around and I wonder, if it could be used with MorphOS to transfer
    sounds and stuff?
    Any ideas or hints, where to start?
    Or will it be impossible ?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »11.08.22 - 14:45
    BatteMan
    Posts: 282 from 2003/2/24
    Got an iPod 3rd Gen here, and I can't mount it on the PowerMac with Firewire (didn't try rear port by the way) but I can mount it and make transfer if I connect it with a USB cable.
  • »11.08.22 - 15:23
