Synergy suggestion
    MoerBoer
    Posts: 237 from 2019/10/15
    I love controlling my MorphOS systems via Synergy from my other machines. ( less keyboard / mouse clutter )
    I'm currently doing it via my MacPro 5.1 using an Apple bluetooth keyboard and mouse. Everything works swimmingly except for the media keys.
    It would be great if there is a possibility to control things like volume up and down via media keys on Synergy.
    Thanks
  • »01.08.22 - 15:43
    Posts: 3210 from 2003/3/5
    Did you bind those keys to anything on the MorphOS side?
  • »01.08.22 - 18:55
    MoerBoer
    Not that I can see.
    If I try for example to try and bind volume up in iControl to some random setting, it just puts a / there.
    Same for Volume down, mute, next, play etc. All of them just gives /
  • »02.08.22 - 15:42
    Posts: 2159 from 2003/2/24
    I don't think media keys can be used in IControl, and I don't remember if they are accepted anywhere in the default MorphOS installation... but they don't give / either...
    I use MMKeyboard to assign actions on those keys, maybe try that if you still get those / characters or do they work actually.
    I've also made a script that can be useful with those media keys: MultiMeedio :)
  • »02.08.22 - 17:28
    MoerBoer
    Thanks jPV, I'll give it a spin.
    Strangely enough, when using my Apple Wired Keyboard (1944) the volume up and down media keys do work, so the OS does support it.
  • »03.08.22 - 03:06
    MoerBoer
    Ok, I installed MMKeyboard.
    With the USB keyboard installed it picks up the volume up ( as example ) correctly, but via Synergy, it just shows /
    USB Keyboard
    Synergy
  • »03.08.22 - 16:30
