Radeon 9600Pro Max Resolution?
    matt3
    Posts: 747 from 2004/2/10
    I pulled my x1950Pro to get multiple monitor support with a radeon 9600Pro. Works great, mouse movement between screens is really sweet!!!
    The maximum resolution I have to choose from is 1280x1024? That seems really low, the card supports much higher resolutions.
    Can I get higher resolutions?
    [ Edited by matt3 17.06.2022 - 23:10 ]
  • »18.06.22 - 00:57
    Posts: 2452 from 2003/2/24
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13204&forum=11#151035
    Suggest that this is not a MorphOS specific issue.
  • »18.06.22 - 05:28
    matt3
    Thanks Kronos!
    I tried switching the cables and that fixed it.
    Now the only issue I have is the mouse goes off the wrong side of the screen. Is there a way to tell MOS which side of the screen to use when moving the mouse to the other screen?
  • »18.06.22 - 10:16
    Posts: 1335 from 2004/2/8
    Here
    Prefs/Presets/Monitors/Layout.txt
    MAIN Radeon9700M.monitor LEFT
    Would place the other monitor on the left side. Needs a reboot.
  • »18.06.22 - 10:25
    matt3
    @koszer
    Worked perfect thanks!
    MOS is really so good now, they are updating it regularly and it is very stable. The multiple monitors with the mouse movement between screens was a huge step for me.
    [ Edited by matt3 18.06.2022 - 17:00 ]
  • »18.06.22 - 18:59
    matt3
    That fixed it thanks!
    Love the ability to click the gadget on the window that pushed the screen instantly to the other monitor and that the screen saver automatically runs on both screens.
    MOS does a much better job that the P96 util in Amiga OS.
    Really sweet!
    matt3 wrote:
    @koszer
  • »21.06.22 - 22:21
