Posts: 157 from 2014/7/15
Hello,
I'm trying to use AmIRC but so far almost no luck. When trying to connect to irc.amigaworld:6667 or irc.libera.chat:6667, if it gets to connect it will take about 2 minutes, but most times it will just stay trying to connect for more than 5 minutes until I abort the connection.
The other problem is that after aborting connection, if I close the Server selection window, CPU usage goes to 100% and I can't even close other windows. Only a reboot fixes it.
Logtool captures no messages and Snoopium captures just after clicking on Connect. Both connections work perfectly with Wookiechat and Momos IRC with the same settings.
I'm running AmIRC 3.8 (3.6 has the same problem) on MOS 3.17
Any hint on what else to check?
Here is the Snoopium log.
[1] [AmIRC] [Open] [KEYPATH] [Read] [Fail]
[2] [AmIRC] [Open] [KEYFILES] [Read] [Fail]
[3] [AmIRC] [Open] [PROGDIR:amirC-3.key] [Read] [Fail]
[4] [AmIRC] [Open] [amirC-3.key] [Read] [Fail]
[5] [AmIRC] [Open] [S:amirC-3.key] [Read] [Fail]
[6] [AmIRC] [Open] [KEYPATH:amirC-3.key] [Read] [Fail]
[7] [AmIRC] [Open] [KEYFILES:amirC-3.key] [Read] [Fail]
[8] [AmIRC] [ToolType] [LANGUAGE] [] [Fail]
[9] [AmIRC] [ToolType] [CONFIG] [] [Fail]
[10] [AmIRC] [ToolType] [CONFIGURATION] [] [Fail]
[11] [AmIRC] [ToolType] [PREFS] [] [Fail]
[12] [AmIRC] [ToolType] [ICONIFY] [] [Fail]
[13] [AmIRC] [ToolType] [ICONIFIED] [] [Fail]
[14] [AmIRC] [ToolType] [NORESETHANDLER] [] [Fail]
[15] [AmIRC] [ToolType] [BORDERRIGHT] [] [Fail]
[16] [AmIRC] [ToolType] [CONNECT] [] [Fail]
[17] [AmIRC] [ToolType] [USENLISTS] [] [Fail]
[18] [AmIRC] [ToolType] [SERVER] [] [Fail]
[19] [AmIRC] [ToolType] [NICK] [] [Fail]
[20] [AmIRC] [ToolType] [AUTOJOIN] [] [Fail]
[21] [AmIRC] [ToolType] [PASSWORD] [] [Fail]
[22] [AmIRC] [ToolType] [OPERSAREKIDS] [] [Fail]
[23] [AmIRC] [ToolType] [TERMINALMODE] [] [Fail]
[24] [AmIRC] [ToolType] [PORT] [] [Fail]
[25] [AmIRC] [Open] [SYS:Data/zoneinfo/GMT] [Read] [Fail]
[26] [AmIRC] [Open] [SYS:Data/zoneinfo/Europe/Madrid] [Read] [Fail]
[27] [AmIRC] [Open] [TIADCC] [Read] [Fail]
[28] [ramlib] [Open] [MOSSYS:LIBS/Textinput.mcc.elf] [Read] [Fail]
[29] [ramlib] [Open] [MOSSYS:LIBS/Textinput.mcc.elf] [Read] [Fail]
[30] [ramlib] [Load] [MOSSYS:LIBS/Textinput.mcc.elf] [] [Fail]
[31] [ramlib] [Open] [MOSSYS:LIBS/Textinput.mcc] [Read] [Fail]
[32] [ramlib] [Open] [MOSSYS:LIBS/Textinput.mcc] [Read] [Fail]
[33] [ramlib] [Load] [MOSSYS:LIBS/Textinput.mcc] [] [Fail]
[34] [ramlib] [Open] [LIBS:Textinput.mcc.elf] [Read] [Fail]
[35] [ramlib] [Open] [LIBS:Textinput.mcc.elf] [Read] [Fail]
[36] [ramlib] [Load] [LIBS:Textinput.mcc.elf] [] [Fail]
[37] [ramlib] [Open] [Textinput.mcc.elf] [Read] [Fail]
[38] [ramlib] [Open] [Textinput.mcc.elf] [Read] [Fail]
[39] [ramlib] [Load] [Textinput.mcc.elf] [] [Fail]
[40] [ramlib] [Open] [LIBS:Textinput.mcc] [Read] [Fail]
[41] [ramlib] [Open] [LIBS:Textinput.mcc] [Read] [Fail]
[42] [ramlib] [Load] [LIBS:Textinput.mcc] [] [Fail]
[43] [ramlib] [Open] [Textinput.mcc] [Read] [Fail]
[44] [ramlib] [Open] [Textinput.mcc] [Read] [Fail]
[45] [ramlib] [Load] [Textinput.mcc] [] [Fail]
[46] [ramlib] [Open] [PROGDIR:LIBS/Textinput.mcc.elf] [Read] [Fail]
[47] [ramlib] [Open] [PROGDIR:LIBS/Textinput.mcc.elf] [Read] [Fail]
[48] [ramlib] [Load] [PROGDIR:LIBS/Textinput.mcc.elf] [] [Fail]
[49] [ramlib] [Open] [PROGDIR:LIBS/Textinput.mcc] [Read] [Fail]
[50] [ramlib] [Open] [PROGDIR:LIBS/Textinput.mcc] [Read] [Fail]
[51] [ramlib] [Load] [PROGDIR:LIBS/Textinput.mcc] [] [Fail]
[52] [ramlib] [Open] [MOSSYS:LIBS/mui/Textinput.mcc.elf] [Read] [Fail]
[53] [ramlib] [Open] [MOSSYS:LIBS/mui/Textinput.mcc.elf] [Read] [Fail]
[54] [ramlib] [Load] [MOSSYS:LIBS/mui/Textinput.mcc.elf] [] [Fail]
[55] [ramlib] [Open] [MOSSYS:LIBS/mui/Textinput.mcc] [Read] [Fail]
[56] [ramlib] [Open] [MOSSYS:LIBS/mui/Textinput.mcc] [Read] [Fail]
[57] [ramlib] [Load] [MOSSYS:LIBS/mui/Textinput.mcc] [] [Fail]
[58] [ramlib] [Open] [LIBS:mui/Textinput.mcc.elf] [Read] [Fail]
[59] [ramlib] [Open] [LIBS:mui/Textinput.mcc.elf] [Read] [Fail]
[60] [ramlib] [Load] [LIBS:mui/Textinput.mcc.elf] [] [Fail]
[61] [ramlib] [Open] [mui/Textinput.mcc.elf] [Read] [Fail]
[62] [ramlib] [Open] [mui/Textinput.mcc.elf] [Read] [Fail]
[63] [ramlib] [Load] [mui/Textinput.mcc.elf] [] [Fail]
[64] [ramlib] [Open] [MOSSYS:LIBS/CManager.library.elf] [Read] [Fail]
[65] [ramlib] [Open] [MOSSYS:LIBS/CManager.library.elf] [Read] [Fail]
[66] [ramlib] [Load] [MOSSYS:LIBS/CManager.library.elf] [] [Fail]
[67] [ramlib] [Open] [MOSSYS:LIBS/CManager.library] [Read] [Fail]
[68] [ramlib] [Open] [MOSSYS:LIBS/CManager.library] [Read] [Fail]
[69] [ramlib] [Load] [MOSSYS:LIBS/CManager.library] [] [Fail]
[70] [ramlib] [Open] [LIBS:CManager.library.elf] [Read] [Fail]
[71] [ramlib] [Open] [LIBS:CManager.library.elf] [Read] [Fail]
[72] [ramlib] [Load] [LIBS:CManager.library.elf] [] [Fail]
[73] [ramlib] [Open] [CManager.library.elf] [Read] [Fail]
[74] [ramlib] [Open] [CManager.library.elf] [Read] [Fail]
[75] [ramlib] [Load] [CManager.library.elf] [] [Fail]
[76] [ramlib] [Open] [LIBS:CManager.library] [Read] [Fail]
[77] [ramlib] [Open] [LIBS:CManager.library] [Read] [Fail]
[78] [ramlib] [Load] [LIBS:CManager.library] [] [Fail]
[79] [ramlib] [Open] [CManager.library] [Read] [Fail]
[80] [ramlib] [Open] [CManager.library] [Read] [Fail]
[81] [ramlib] [Load] [CManager.library] [] [Fail]
[82] [ramlib] [Open] [PROGDIR:LIBS/CManager.library.elf] [Read] [Fail]
[83] [ramlib] [Open] [PROGDIR:LIBS/CManager.library.elf] [Read] [Fail]
[84] [ramlib] [Load] [PROGDIR:LIBS/CManager.library.elf] [] [Fail]
[85] [ramlib] [Open] [PROGDIR:LIBS/CManager.library] [Read] [Fail]
[86] [ramlib] [Open] [PROGDIR:LIBS/CManager.library] [Read] [Fail]
[87] [ramlib] [Load] [PROGDIR:LIBS/CManager.library] [] [Fail]
[88] [ramlib] [Open] [MOSSYS:LIBS/mui/Levelmeter.mui.elf] [Read] [Fail]
[89] [ramlib] [Open] [MOSSYS:LIBS/mui/Levelmeter.mui.elf] [Read] [Fail]
[90] [ramlib] [Load] [MOSSYS:LIBS/mui/Levelmeter.mui.elf] [] [Fail]
[91] [ramlib] [Open] [MOSSYS:LIBS/mui/Levelmeter.mui] [Read] [Fail]
[92] [ramlib] [Open] [MOSSYS:LIBS/mui/Levelmeter.mui] [Read] [Fail]
[93] [ramlib] [Load] [MOSSYS:LIBS/mui/Levelmeter.mui] [] [Fail]
[94] [ramlib] [Open] [LIBS:mui/Levelmeter.mui.elf] [Read] [Fail]
[95] [ramlib] [Open] [LIBS:mui/Levelmeter.mui.elf] [Read] [Fail]
[96] [ramlib] [Load] [LIBS:mui/Levelmeter.mui.elf] [] [Fail]
[97] [ramlib] [Open] [mui/Levelmeter.mui.elf] [Read] [Fail]
[98] [ramlib] [Open] [mui/Levelmeter.mui.elf] [Read] [Fail]
[99] [ramlib] [Load] [mui/Levelmeter.mui.elf] [] [Fail]
[100] [AmIRC] [Open] [muidebug] [Read] [Fail]
[101] [AmIRC] [Open] [REALNAME] [Read] [Fail]
[102] [ramlib] [Open] [PROGDIR:Plugins/XDCC.AmIPlug.elf] [Read] [Fail]
[103] [ramlib] [Open] [PROGDIR:Plugins/XDCC.AmIPlug.elf] [Read] [Fail]
[104] [ramlib] [Load] [PROGDIR:Plugins/XDCC.AmIPlug.elf] [] [Fail]
[105] [ramlib] [Open] [PROGDIR:Plugins/Data/XDCC.data] [Read] [Fail]
[106] [ramlib] [Open] [PROGDIR:Plugins/WallChop.AmIPlug.elf] [Read] [Fail]
[107] [ramlib] [Open] [PROGDIR:Plugins/WallChop.AmIPlug.elf] [Read] [Fail]
[108] [ramlib] [Load] [PROGDIR:Plugins/WallChop.AmIPlug.elf] [] [Fail]
[109] [ramlib] [Open] [PROGDIR:Plugins/CManager.AmIPlug.elf] [Read] [Fail]
[110] [ramlib] [Open] [PROGDIR:Plugins/CManager.AmIPlug.elf] [Read] [Fail]
[111] [ramlib] [Load] [PROGDIR:Plugins/CManager.AmIPlug.elf] [] [Fail]
[112] [ramlib] [Open] [MOSSYS:LIBS/CManager.library.elf] [Read] [Fail]
[113] [ramlib] [Open] [MOSSYS:LIBS/CManager.library.elf] [Read] [Fail]
[114] [ramlib] [Load] [MOSSYS:LIBS/CManager.library.elf] [] [Fail]
[115] [ramlib] [Open] [MOSSYS:LIBS/CManager.library] [Read] [Fail]
[116] [ramlib] [Open] [MOSSYS:LIBS/CManager.library] [Read] [Fail]
[117] [ramlib] [Load] [MOSSYS:LIBS/CManager.library] [] [Fail]
[118] [ramlib] [Open] [LIBS:CManager.library.elf] [Read] [Fail]
[119] [ramlib] [Open] [LIBS:CManager.library.elf] [Read] [Fail]
[120] [ramlib] [Load] [LIBS:CManager.library.elf] [] [Fail]
[121] [ramlib] [Open] [CManager.library.elf] [Read] [Fail]
[122] [ramlib] [Open] [CManager.library.elf] [Read] [Fail]
[123] [ramlib] [Load] [CManager.library.elf] [] [Fail]
[124] [ramlib] [Open] [LIBS:CManager.library] [Read] [Fail]
[125] [ramlib] [Open] [LIBS:CManager.library] [Read] [Fail]
[126] [ramlib] [Load] [LIBS:CManager.library] [] [Fail]
[127] [ramlib] [Open] [CManager.library] [Read] [Fail]
[128] [ramlib] [Open] [CManager.library] [Read] [Fail]
[129] [ramlib] [Load] [CManager.library] [] [Fail]
[130] [ramlib] [Open] [PROGDIR:LIBS/CManager.library.elf] [Read] [Fail]
[131] [ramlib] [Open] [PROGDIR:LIBS/CManager.library.elf] [Read] [Fail]
[132] [ramlib] [Load] [PROGDIR:LIBS/CManager.library.elf] [] [Fail]
[133] [ramlib] [Open] [PROGDIR:LIBS/CManager.library] [Read] [Fail]
[134] [ramlib] [Open] [PROGDIR:LIBS/CManager.library] [Read] [Fail]
[135] [ramlib] [Load] [PROGDIR:LIBS/CManager.library] [] [Fail]
[136] [ramlib] [Open] [MOSSYS:LIBS/Busy.mcc.elf] [Read] [Fail]
[137] [ramlib] [Open] [MOSSYS:LIBS/Busy.mcc.elf] [Read] [Fail]
[138] [ramlib] [Load] [MOSSYS:LIBS/Busy.mcc.elf] [] [Fail]
[139] [ramlib] [Open] [MOSSYS:LIBS/Busy.mcc] [Read] [Fail]
[140] [ramlib] [Open] [MOSSYS:LIBS/Busy.mcc] [Read] [Fail]
[141] [ramlib] [Load] [MOSSYS:LIBS/Busy.mcc] [] [Fail]
[142] [ramlib] [Open] [LIBS:Busy.mcc.elf] [Read] [Fail]
[143] [ramlib] [Open] [LIBS:Busy.mcc.elf] [Read] [Fail]
[144] [ramlib] [Load] [LIBS:Busy.mcc.elf] [] [Fail]
[145] [ramlib] [Open] [Busy.mcc.elf] [Read] [Fail]
[146] [ramlib] [Open] [Busy.mcc.elf] [Read] [Fail]
[147] [ramlib] [Load] [Busy.mcc.elf] [] [Fail]
[148] [ramlib] [Open] [LIBS:Busy.mcc] [Read] [Fail]
[149] [ramlib] [Open] [LIBS:Busy.mcc] [Read] [Fail]
[150] [ramlib] [Load] [LIBS:Busy.mcc] [] [Fail]
[151] [ramlib] [Open] [Busy.mcc] [Read] [Fail]
[152] [ramlib] [Open] [Busy.mcc] [Read] [Fail]
[153] [ramlib] [Load] [Busy.mcc] [] [Fail]
[154] [ramlib] [Open] [PROGDIR:LIBS/Busy.mcc.elf] [Read] [Fail]
[155] [ramlib] [Open] [PROGDIR:LIBS/Busy.mcc.elf] [Read] [Fail]
[156] [ramlib] [Load] [PROGDIR:LIBS/Busy.mcc.elf] [] [Fail]
[157] [ramlib] [Open] [PROGDIR:LIBS/Busy.mcc] [Read] [Fail]
[158] [ramlib] [Open] [PROGDIR:LIBS/Busy.mcc] [Read] [Fail]
[159] [ramlib] [Load] [PROGDIR:LIBS/Busy.mcc] [] [Fail]
[160] [ramlib] [Open] [MOSSYS:LIBS/mui/Busy.mcc.elf] [Read] [Fail]
[161] [ramlib] [Open] [MOSSYS:LIBS/mui/Busy.mcc.elf] [Read] [Fail]
[162] [ramlib] [Load] [MOSSYS:LIBS/mui/Busy.mcc.elf] [] [Fail]
[163] [ramlib] [Open] [MOSSYS:LIBS/mui/Busy.mcc] [Read] [Fail]
[164] [ramlib] [Open] [MOSSYS:LIBS/mui/Busy.mcc] [Read] [Fail]
[165] [ramlib] [Load] [MOSSYS:LIBS/mui/Busy.mcc] [] [Fail]
[166] [ramlib] [Open] [LIBS:mui/Busy.mcc.elf] [Read] [Fail]
[167] [ramlib] [Open] [LIBS:mui/Busy.mcc.elf] [Read] [Fail]
[168] [ramlib] [Load] [LIBS:mui/Busy.mcc.elf] [] [Fail]
[169] [ramlib] [Open] [mui/Busy.mcc.elf] [Read] [Fail]
[170] [ramlib] [Open] [mui/Busy.mcc.elf] [Read] [Fail]
[171] [ramlib] [Load] [mui/Busy.mcc.elf] [] [Fail]
[172] [AmIRC Connect Requester Handler] [Open] [muidebug] [Read] [Fail]
PowerBook 5.2 MorphOS 3.15
PowerBook 5.8 MorphOS 3.15
Amiga 1200 BPPC/BVision AOS4.1 FE
