SmbFS with SMB2 support?
  • MDW
    MDW
    Posts: 483 from 2003/7/25
    Is on MorphOS any way for connect to network using SMB2? SmbFS works very well but supports only SMB1 which is not recommended today. Any plans to add SMB2 support in SmbFS?
    [ Edited by MDW 17.05.2022 - 19:24 ]
  • »17.05.22 - 15:22
    ernsteiswuerfel
    Posts: 567 from 2015/6/17
    This would be a very welcome improvement indeed! Starting with samba 4.16.x some more SMB1 options get removed (klick). Don't know how/whether this hampers MorphOS SMB-client..
    PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.19 / Adelie Linux / Gentoo Linux] | A600GS [Amibench / OS 3.2] | Talos II Secure Workstation. [Gentoo Linux]
  • »17.05.22 - 18:19
    Posts: 545 from 2003/4/11
    Well, if it was that simple to "update" SmbFS to SMB2, Olaf "olsen" Barthel or anyone involved in SmbFS from MorphOS Team would probably have been looked into it by now.
    We are well aware of the "SMB1 problem" but there is no elegant short-term solution to it for now. I worked on some aspects of the MorphOS port but personally I would probably go for a full rewrite instead of messing around with the old code.
    Maybe some "3rd party" is able to look into some solution using FUSE compatible filesysbox.library, AFAIR there has been some SMB for FUSE solution but I never really looked closer into it.
  • »20.05.22 - 18:20
  • MDW
    MDW
    Yes... I know that this is not trivial task. However I hope maybe some day... someone... :)
  • »20.05.22 - 19:19
