Wayfarer e twitchTV
    Posts: 158 from 2019/4/6
    @BeWorld
    Thanks for the new version of FFPlay 4.4.1 and your work.
    I tried the new version
    You also added Altivec support, thanks.
    It has improved a lot at least in the use I try to make of it personally associated with "AmiTube" to watch streams on TwitchTV.
    There are still incompatibilities but it has improved a lot.
    I noticed only one inconvenience that I point out maybe you can solve it.
    In practice, once the streaming starts if I want to close the FFPlay window in which I am viewing the video, it cannot be closed and effectively blocks all subsequent streams.
    (I have installed the latest version 2.0 sdl)
    In the old version of FFPlay 4.4 this never happened the window closed without any problem.
    Thanks again
    I made a video using "qemu" to let you know what I mean is it is in the last part of the video but it also happens on the PowerBook.
    which you can find here:
    https://we.tl/t-jxbatw1Um0
    a little note:
    @jacadcaps
    WayFarer 3.2 reports a crash many times after simply copying the video link to "pass" to AmiTube.
    I sent the reports with the appropriate notification included in "WayFarer"
    Thanks, maybe it's useful.
  • »27.03.22 - 17:32
    beworld
    Posts: 544 from 2010/2/10
    FFPlay:
    i will delete ffplay from archive... this version is completly instable...
    i will check if i can fix that.
    IMac G5 2.1,PowerMac 2.7,PowerBook 1.5
    My MOS ports
  • »27.03.22 - 18:00
    @beworld
    Thanks it would be very nice to use FFPlay to watch the streams :-)
    I wanted to ask for some valuable advice
    with morphos how do you kill a process:
    in this case ffplay
    for example it is right:
    "ikill ffplay" ?
    Thank you.
  • »27.03.22 - 18:04
    beworld
    yes you can do this... but FFplay crash system... better is reboot :-)
    and use MPLayer to play video... better solution
    [ Edité par beworld 27.03.2022 - 21:28 ]
    My MOS ports
  • »27.03.22 - 18:15
    @beworld
    Thanks for the reply :-)
  • »27.03.22 - 18:25
    walkero
    Posts: 91 from 2006/3/1
    I wanted to add here that mplayer is not able to play live streams in a watchable way, and the reason is that the live streams are usually playlist m3u8 files with the video broken into small 5-10sec chunks. Although that mplayer is able to use this kind of file, it stops before it plays the next part, so you have a bad video playback experience.
    This is happening on Linux as well. When I was experimenting and was searching if there is a way to overcome that behaviour, I didn't find a way, but I might miss something.
    That's why ffplay is better to playback those video streams.
  • »29.03.22 - 19:03
    beworld
    mmmm, thanks walkero.
    I will try to fix it... but no promise.
    My MOS ports
  • »29.03.22 - 19:14
    @walkero
    @beworld
    exactly, I had already tried this solution some time ago '
    with WayFarer:
    here I use twitchTV (aiostreams) "walkero" site to get the link
    with the "jacadcaps" tool to get the "m3u8"
    and pass it to MPlayer (morphos)
    and it happens exactly what described by "walkero"
    I apologize if I used qemu for the test (I'm still trying to get the audio to work) :-)
    here the test with a short video:
    in reality the video is seen and continues in the vision but in "segments" and at a certain point it ends.
    https://we.tl/t-UAZrCcwjTg
    [ Edited by white 30.03.2022 - 01:13 ]
  • »29.03.22 - 22:07
    while here the same procedure described as above works perfectly with:
    ffplay and emotion using winuae (4.1)
    https://we.tl/t-8DXClUvBgT
  • »29.03.22 - 22:59
    For those who want to try amitube
    here the link:
    https://www.morphos-storage.net/?id=1728829
    unpacking it is launching it the first time and closing it.
    an .ini file will be created in its folder.
    which does manually configured like this for Morphos:
    [Player]
    Path = Sys: Utilities / MultiView
    Parameter =% f
    MPEGPath = Sys: Utilities / MultiView
    MPEGParameter =% f
    URLPlayerPath = Work: FFMpeg / ffplay <--- ffplay path
    URLParameter =% u <--- here any parameters for ffplay but it's fine by default.
    WGetPath = C: wget
    WGetParameter =% u -O% f
    re-launch it (there is also a way to configure it with the interface but I prefer it this way)
    here is the fastest video to get the links to pass to AmiTube and the tests I have done that work:
    (for convenience i used qemu to make a quick video)
    as you can see from the video, multiple streams are launched at the same time without any block
    https://we.tl/t-kW5X2tU1Ue
    Currently with ffplay it works but it seems to somehow support one process at a time.
    I hope it is useful.
    Or someone can help.
    Thanks to "beworld" for his availability and his work.
    [ Edited by white 31.03.2022 - 23:03 ]
  • »31.03.22 - 19:58
