Posts: 180 from 2008/7/10
Quote:Zetec-s wrote:
beworld wrote:
ok so on testgamecontroller, you see : "XBox 360 Controller" (1 game controller attached)
if yes, normally you can use your controller with ZGloom...
On ZGloom's menu, you can use PAD to choose option and 2 STICKs and 1 button to play on game.
Sorry for appearing stupid but where is that menu, as I cannot find it?
If I go into Gloom Deluxe for example I don't have the option to use PAD.
Sorry I’ve realised you mean it should just let me use the game pad on the menus and the dual sticks in the game but it doesn’t.
Have I not got SDL2 set up correctly?
The same happens on my PowerBook and my G5.
PowerMac G5 Quad 2.5Ghz/2GB MorphOS 3.17 Registered
Powerbook 1.67Ghz/1.5GB MorphOS 3.17 Registered
MacMini 1.5Ghz/1GB MorphOS 3.17 Registered
