Anybody help?
    Tomtom76
    Posts: 21 from 2021/6/26
    Hello. Im newie in MorphOS. Trying to sort out my WHDLOpener working properly. My ADFs and WHDLoad games are working but still whatever I do still have sound problems. I did ask on another Amiga forum but no fun. Anybody can share a properly working configs pls? My machine is Powerbook g4 A1106, all possible MorphOS 3.15 RAM. Thanks
  • »31.07.21 - 19:12
    tolkien
    Posts: 502 from 2013/5/29
    I guess you are using latest UAE with jit enabled. Perhaps you can change your AHI sound settings.
    Im away from my morphos machines so can look for my settings sorry.
  • »01.08.21 - 14:38
    Korni
    Posts: 471 from 2006/2/23
    Can you elaborate about the sound problems?
  • »01.08.21 - 14:38
    Tomtom76
    Im using UAE which comes with WHDLOpener so its 1.0 and yes using it with JIT enabled. Just have glitches in almost every game i play. Specially Digital Illusions Pinballs. Probably very demanding games. Its just now and again sound interruptions when the Amiga emulated processor reach over 100% if i am not using JIT compiler. With JIT on its better but still problem with sound exist.
    Example UAE settings:
    kickstart_rom_file=PROGDIR:Roms/kick40068.A1200
    kickstart_key_file=PROGDIR:Roms/rom.key
    filesystem=rw,AmigaOS:PROGDIR:HardDisks/AOS31WHD
    #filesystem=rw,Games:Games:
    #filesystem=rw,Work:Work:
    #filesystem=rw,MorphOS:MorphOS:
    filesystem=rw,RAM2:RAM:
    filesystem=rw,Boot:Boot:
    filesystem=rw,Usb8:Usb8:
    filesystem=rw,System:System:
    filesys_nofsdb=true
    comp_optimize=yes
    cachesize=8192
    comp_constjump=no
    comp_trustbyte=indirect
    comp_trustword=indirect
    comp_trustlong=indirect
    # cpu settings
    cpu_type=68040
    cpu_speed=max
    cpu_compatible=false
    cpu_cycle_exact=true
    cpu_24bit_addressing=no
    # chipset settings
    chipset=aga
    immediate_blits=false
    fast_copper=true
    #collision_level=full
    #blitter_cycle_exact=false
    # memory settings
    fastmem_size=0
    chipmem_size=8
    z3mem_size=128
    # gfx settings
    gfx_width=320
    gfx_height=256
    gfx_width_windowed=666
    gfx_height_windowed=532
    gfx_width_fullscreen=666
    gfx_height_fullscreen=532
    gfx_lores=false
    gfx_colour_mode=24bit
    gfx_linemode=double
    #double, none, scanlines
    gfx_center_horizontal=true
    gfx_center_vertical=true
    gfx_fullscreen_amiga=true
    gfx_fullscreen_picasso=true
    gfx_vsync=true
    show_leds=true
    gfxcard_size=32
    # sound settings (sound_output="normal" or "none")
    # (sound_channels="stereo or "mono" or "mixed")
    # (sound_bits="8" or "16")
    sound_output=normal
    sound_bits=8
    sound_channels=mixed
    sound_frequency=22050
    # joy <n> where n is lowlevel unit in amigaos target. In SDL target it's the enumeration order.
    joyport0=mouse
    joyport1=joy 1
    # overlay display
    amiga.use_overlay=true
    # screen type (public, custom or ask)
    amiga.screen_type=custom
    # slow and endianess issue.Better don't use
    #sdl.use_gl=no
  • »01.08.21 - 15:53
    tolkien
    This is my config file.
    First, I emulate a 020 instead a 040. A 020 is nice to play games :)
    Second, I use 16 bits sounds.
    I have to tweak this config a bit but It works nice in my g5 setup.
    filesystem=rw,Data:Data:
    filesys_nofsdb=true
    # cpu settings
    cpu_type=68020
    cpu_speed=real
    #cpu_cycle_exact=true
    # chipset settings
    chipset=aga
    immediate_blits=true
    #fast_copper=false
    #blitter_cycle_exact=true
    # memory settings
    fastmem_size=4
    chipmem_size=4
    z3mem_size=4
    # gfx settings
    gfx_width=320
    gfx_height=256
    gfx_width_windowed=320
    gfx_height_windowed=256
    gfx_width_fullscreen=320
    gfx_height_fullscreen=256
    gfx_lores=yes
    #gfx_colour_mode=8bit
    gfx_linemode=none
    #gfx_fullscreen_amiga=true
    #gfx_fullscreen_picasso=true
    #gfx_vsync=true
    #show_leds=true
    #gfxcard_size=32
    sound_output=normal
    sound_bits=16
    sound_channels=stereo
    sound_frequency=44100
    joyport0=mouse
    joyport1=kbd1
    # overlay display
    amiga.use_overlay=false
    #sdl.use_gl=no
  • »01.08.21 - 16:24
    Tomtom76
    Thank you Tolkien.
    Your settings do not makes any difference unfortunately. Maybe cos your machine is much stronger. I appreciate your help anyway. Maybe my AHI need attention. Ill try play with those settings and will let know if will be any better
  • »01.08.21 - 16:59
    cip060
    Posts: 137 from 2010/7/30
    if you only use it for adf or whdload games
    it would be recommended and useless to use the JIT !!
  • »01.08.21 - 23:13
    Posts: 12085 from 2003/5/22
    > if you only use it for adf or whdload games it would
    > be […] useless to use the JIT !!
    Why? JIT makes sense if you emulate a 68020 or above, and especially with WHDLoad, as that makes 68000 games compatible with newer 68k CPUs.
  • »01.08.21 - 23:58
    Tomtom76
    I was playin with my settings and found working perfectly now
    comp_optimize=yes
    cachesize=8192
    comp_constjump=no
    # cpu settings
    cpu_type=68040
    cpu_speed=max
    # chipset settings
    chipset=aga
    fast_copper=true
    # memory settings
    fastmem_size=0
    chipmem_size=8
    z3mem_size=128
    # gfx settings
    gfx_width=320
    gfx_height=256
    gfx_lores=false
    gfx_linemode=double
    gfx_vsync=true
    show_leds=true
    gfxcard_size=32
    sound_output=normal
    sound_bits=16
    joyport0=mouse
    joyport1=joy 1
    # overlay display
    #sdl.use_gl=no
    So thank you all for advices :-)
  • »02.08.21 - 11:35
