Problem with SnapIt and Grabber
    Papiosaur
    Posts: 2041 from 2003/4/10
    Hello,
    i have a problem (two problems)
    First problem:
    I have this graphic bug this SnapIt:
    https://www.morphos-storage.net/Graphics/Mathematics/ZoneXplorer2BETA.png
    I have contacted the author but maybe it's a problem of MorphOS, so i post here too.
    Second problem:
    When i would like to change save path in Grabber prefs, clock continue and cursor continue to blink but mouse and keyboard are freezed...
    Any ideas ?
    Thanks
    [ Edité par Papiosaur 06.05.2021 - 16:17 ]
  • »06.05.21 - 14:58
    Posts: 888 from 2004/1/24
    Papiosaur wrote:
    Hello,
    First problem:
    Second problem:
    Any ideas ?
    Thanks
    No idea, but you might want to give Screenshot a try :-)
  • »06.05.21 - 16:27
    Posts: 779 from 2007/10/23
  • »08.05.21 - 00:05
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Papiosaur!
    SnapIT seems not to be much friendly with ZoneXplorer window or vice versa. I don't know why but when you grab the window it makes an image with trashed borders and this doesn't happen with other opened windows on Ambient. This doesn't happen if you use free-hand grab.
    Grabber works flawless here, the .sbar version too.
    Screenshot, the program Stevo suggested you, makes grabs but no window borders.
    By the way: Stevo the link doesn't work =)
    [ Edited by Jambalah 08.05.2021 - 15:38 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.05.21 - 14:26
    kriz
    Posts: 309 from 2005/10/18
    http://amigazeux.org/ is not working since some time now :/
  • »08.05.21 - 19:31
    todi
    Posts: 140 from 2003/2/18
    Sorry about that, it's fixed now.
    ToDi
    amigazeux.org
  • »09.05.21 - 18:31
    Thanks ToDi :-D
  • »09.05.21 - 19:22
    Papiosaur
    Jambalah a écrit :
    Hi Papiosaur!
    Hi Jambalah, thanks for your return ;-)
    I have realized a good screenshot with Grabber, maybe a problem with SnapIt...
  • »09.05.21 - 20:35
    Posts: 537 from 2003/4/11
    Papiosaur schrieb:
    Hello,
    First problem:
    While you seem to have resolved the window snapshot issue by now, it might be due to the fact that the control panel window is using a GIMMEZEROZERO window which stores the window border differently and some grabbers are not able to deal with it properly.
  • »13.05.21 - 22:56
    Develin
    Posts: 100 from 2003/4/19
    Now Papio allready knows about this fixed new version of SnapIT but in case someone missed it it's released which handles the GIMMEZEROZERO-windows =)
    https://www.onyxsoft.se/snapit.html
  • »15.06.21 - 17:06
