MorphOS and HDMI video grabber
  • K-L
    K-L
    Posts: 42 from 2020/11/17
    I'm using this one
    Here are the videos I made with it for MorphOS (using a DVI to HDMI cable with my Radeon 9650) :
    MorphOS vidéos
    Quality is not perfect but the job is done in Full HD/60 FPS (recorded with a Mac Pro 2013):)
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »24.05.21 - 10:19
    Posts: 1246 from 2004/2/8
    K-L wrote:
    I'm using this one : https://www.ebay.fr/itm/233790419216?hash=item366efeb110
    Here are the videos I made with it for MorphOS (using a DVI to HDMI cable with my Radeon 9650) : https://video.amiga-ng.org/search?tagsOneOf=Morphos
    Quality is not perfect but the job is done :)
    I'm using a Velocap TBox Mini (the one seen here) myself and you can see the effect here:
    https://youtu.be/0PjLR8Yn3rk
  • »24.05.21 - 14:40
    Chain-Q
    Posts: 347 from 2003/10/12
    @koszer
    That video looks nice, but it's only 30fps it seems. Does this capture/recording device do 50/60fps as well?
    @Thread
    Since everyone is posting their recordings, here is one from my Efika and current recording setup, which is a combination of an Extron DSC 301 HD, and an Elgato Game Capture HD60S+. With the Extron, I scale everything to full HD and properly sync'd to 60Hz, then use the Game Capture to record it. This was recorded from the VGA out of the Radeon 9250 inside the Efika.
    https://www.youtube.com/watch?v=9cPERGT20E8
    The video was about testing the speed of MorphOS' 68k emulation, because someone in a Hungarian forum claimed that the Vampire is faster, because it's not possible to run a 060 demo smooth on any MorphOS hardware. So I took Shake off the Dust by Elude, my Efika (the slowest officially supported MorphOS hardwre), tweaked Trance a bit in Taskmanager, and this was the result. So it's mostly actually a 320x200 low-res demo, but before-after there's some high res (1024x768, but scaled) GUI footage as well.
    [.Hosting AmigaSpirit.hu.]
  • »25.05.21 - 10:35
    Chain-Q wrote:
    @koszer
    Yes, but not in FullHD, unfortunately. It can capture video at 60 FPS in 720p only.
  • »25.05.21 - 17:37
    discreetfx
    Posts: 388 from 2003/7/26
    You can grab MorphOS screenshots and video with the NewTek Spark. It works like a charm and grabs anything you need.
    https://www.newtek.com/spark/
    [ Edited by discreetfx 25.05.2021 - 17:37 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »25.05.21 - 22:35
  • rms
    rms
    Posts: 599 from 2004/11/27
    can you tell which model of them are you using?
    Spark Plus IO 4K
    Spark Plus IO 3G-SDI
    Spark Plus IO 12G-SDI
    Spark Plus 4K
    Thanks
    Christoph
  • »26.05.21 - 03:56
    Trekman
    Posts: 25 from 2020/11/10
    Hello all , :-)
    Elgato HD60S works here fine at 720p.
    Look here : https://www.youtube.com/watch?v=6RBYJgiTmA4
  • »26.05.21 - 13:21
    discreetfx
    @rms
    Any of the NewTek Sparks should work with the exception of the SDI ones I believe. I use the ones that came with my TriCaster Mini 4K.
    [ Edited by discreetfx 28.05.2021 - 20:57 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »27.05.21 - 15:44
