After Reboot Blank screeen
    gothor
    Posts: 32 from 2011/4/6
    i rebooted by Powermag G5. After Reboot i only see a blank white screen. i have the mous poniter and i see the logo from Morphos and "Ambient Screen". Could sombody help me? As a graphic card i have a 1950Pro.
    Thx for help
    Gothor
  • »24.03.21 - 13:57
    gothor
    After Update with 3.15 again it stucks in the bootscreen. i should make a new installation
  • »24.03.21 - 14:14
    Posts: 1246 from 2004/2/8
    Does it happen every time you reset the computer?
  • »24.03.21 - 16:33
    Posts: 2971 from 2003/3/5
    Sounds like some configuration / file system issue. Boot from CD/USB and run SFSDoctor on the system partition. If that doesn't help, run IWizard Update.
  • »24.03.21 - 17:31
    gothor
    Thx for your help,
    i mad a backup an reinstalled the system
    Gothor
  • »25.03.21 - 06:17
