Posts: 1475 from 2012/11/10
I know it has been sitting here a while, this request for information, but I've only just seen it, and it doesn't seem to have got very far, and maybe you are still waiting for a solution.
However, initially it would be good to have the specific model identified as all I see is Epson Stylus 750 - is that the full name of the model or does it have a 'XP' as part of the full name of the printer (I don't mean WinXP) or any other specific details, or a link to the exact model of this printer, or is it some really old Epson - no-longer-supported-by-Epson - inkjet printer? What year was it manufactured? Does it have PostScript capabilities? Do you have the original or a copy of the original installation CD for it?
The Printers Prefs in MorphOS v3.10+ requires you to supply the associated PPD (Postscript Printer Description) file for the printer - do you have that? Or, know where to get it from?
If your printer does not have any PostScript capabilities then you should use the 'Printer' Prefs (the one with no "s" on the end of the word "Printer"). If you click on NEW you will be offered numerous older printers that you should be able to select one of the older Epson printers with a suitable capability to the one you have that will allow you to print from MorphOS. You will have to choose a suitable printer device, Parallel/Serial/Device (usually these are USB Parallel/Serial or other device that you choose, but they are listed simply as I just stated) from a button on the right of the Printer Prefs window and hopefully that should allow you to print using TurboPrint which is embedded in MorphOS as the default printing option though you can choose GhostScript, which you would have to install, probably through using/launching the "Grunch" program.
I hope this information is useful, and solves your problem, unless you've already managed to work out how to print from your printer already with MorphOS.
