#AmigaZeux update corner
    redrumloa
    Posts: 1424 from 2003/4/13
    KennyR wrote:
    AminetRadio has been looked at recently (especially in regard to squashing bugs and implenting a ShoutCast alternative), but the main problem holding things back is that MUI has diverged significantly. The intention is that it should always be an Amiga app that can run on MorphOS, but this is difficult if you have to support (and betatest) MUI 3.8, MUI 3.9, MUI 3.9 on OS4, MUI4 on MorphOS, MUI4 on OS4 and MUI 4 on 68k.
    This is incredibly tedious to wade through and the author gelb just doesn't have the same time he used to.
    gelb should just drop support for pirate MUI.
  • »16.04.20 - 17:01
    ultragelb
    Posts: 6 from 2018/10/7
    Stevo wrote:
    And the updates keep coming! We are pleased to present Screenbar-Plugin V1.2, enjoy!
    Just another small update since Preview and TestPaint would crash when drawing outside the visible canvas. Easily tested by using the Symmetry Tool and drawing f.ex. circles.
    So here's:
    V1.21 (16.04.2020)
    - TestPaint: Display optimizations of V1.2 had an off-by-one bug causing all kinds of crashes when drawing supposedly outside the canvas.
    Just redownload the Archive and sorry for the hassle.
  • »16.04.20 - 19:42
    ultragelb
    Papiosaur wrote:
    Thanks ultragelb for this excellent screenbar module!
    New archive has lower size (344K) than 1.2 version (516Kb)...
    A mistake ?
    Thank you for pointing this out. It's indeed a mistake. The actual sbar plugin (Screenshot.sbar) is missing from the archive :-/
    I've reuploaded the archive now.
    Sorry to everyone for this mess-up, but hey, it generates some traffic at least :-)
  • »16.04.20 - 21:43
    Posts: 888 from 2004/1/24
    The main cheese is at it again. With pride, we at #amigazeux proudly present
    TopTasks Screenbar-Plugin V1.4
    TopTasks.sbar is a Screenbar-Plugin for MorphOS that shows the task currently eating the most CPU time.
    When clicked it opens a window showing the top 10 tasks currently hogging all your precious CPU time. Furthermode it can display a history of the top tasks of the last 100 seconds.
    New in this version:
    * Shows Niceness, Process ID (PID) and age of each task in the top tasklist.
    * Now also shows running/sleeping, created/finished and average CPU load below the tasklist.
    * Strings in top task list entries context menu items (priority, break, etc) are now localized too
  • »01.05.20 - 20:08
    mahen
    Posts: 118 from 2003/2/24
    Howdy there !
    +1000 for an ANR update, my dream audio player :-) I was shocked when it was first released as it was exactly the player I was looking for !
    But indeed, I guess sticking to a single build / platform target would be more realistic.
    [ Edited by mahen 22.08.2020 - 23:43 ]
    xmpp:mahen on jabber.fr
  • »25.07.20 - 14:13
    mahen
    Oh, BTW, nowadays, ANR badly needs a Flac plugin :-)
  • »22.08.20 - 22:44
    Drako^lM
    Posts: 144 from 2005/8/10
    FLAC player for AmiNetRadio
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »26.08.20 - 19:17
    todi
    Posts: 140 from 2003/2/18
    I've added it now to the players page of ANR. :D
    ToDi
    amigazeux.org
  • »03.09.20 - 19:20
    Today, the Gelbest of all presents not one, not two but a whopping ten critical updates and one new screenbar plugin.
    We at #amigazeux thank Thomas Igracki for not only pointing out a critical bug, but also for supplying a fix for the ECX compiler's library generation code :-)
    Go here and cheer!
  • »23.01.21 - 16:31
    Samurai_Crow
    Posts: 153 from 2009/12/10
    Will there be an ECX update as well? Having looked into creating a fork of it, I think most of what's required is to make the new fork under a different name.
  • »23.01.21 - 20:53
    Herr
    Gelb did it again! #amigazeux proudly presents TopTasks Screenbar-Plugin V1.6
    TopTasks.sbar is a Screenbar-Plugin for MorphOS that shows the task that is currently eating the most CPU time in the screen title
    When the titlebar object is clicked it opens a window displaying the top tasks (from 5 to 25) currently hogging all your precious CPU time. Furthermore it can display a history of the top tasks of the last configureable number of seconds/minutes/hours.
    Visit #amigazeux central and be amazed.
  • »25.05.22 - 21:44
    It pleases Gelbman to present version 1.3 of MouseTracker. It's a big update, so check it out!
  • »06.07.22 - 16:38
    Better late than never: Lupe V2.1!
  • »29.10.22 - 20:44
