Installing MorphOS 3.15 from a Flashdrive
    discreetfx
    Posts: 399 from 2003/7/26
    Is there anyway to install MorphOS 3.15 from a USB Thumb-drive? It appears that my Mac mini’s CD drive has gone bad.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.01.21 - 16:48
    discreetfx
    I also have an external USB DVD Burner. Maybe there’s a way to install MorphOS that way?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.01.21 - 16:51
    Posts: 906 from 2004/1/24
    https://www.morphos-team.net/guide/usb-boot
  • »14.01.21 - 17:07
    discreetfx
    I tried that but could not get the open firmware screen to come up.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.01.21 - 17:56
    Posts: 2159 from 2003/2/24
    Double check that you press the correct keys (not ctrl), try pressing them when you hear first sounds from the CD drive (not before), try connecting keyboard directly to the machine if it's on a hub...
    Does it boot to the OS when you don't succeed or does it stay in a black screen or something like that?
    [ Edited by jPV 14.01.2021 - 21:32 ]
  • »14.01.21 - 18:30
    discreetfx
    @jPV
    I connected keyboard directly to the Mac mini but it is a cheap mini keyboard. I guess I’ll try one of my TriCaster keyboards. It boots into MorphOS 3.14 so it’s not seeing my key presses I guess.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.01.21 - 20:26
    discreetfx
    TriCaster keyboard worked, thanks for the help guys. I believe I’m good to go now.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.01.21 - 20:36
    Posts: 37 from 2019/9/5
    discreetfx wrote:
    @jPV
    It is kind of tricky with an external keyboard. Keep trying with different methods. I've used three different keyboards so far with my Mac Mini and all have worked somehow.
  • »15.01.21 - 15:10
