How to change the look of Ambient's menu?
    Posts: 30 from 2019/9/5
    Hello everyone,
    Probably a dumb question but I couldn't find the setting where I can change the look of Ambient's menu (bg color specifically).
    I can edit the context menu's appearance, but the main menu stays intact.
  • »22.10.20 - 17:02
    Korni
    Posts: 467 from 2006/2/23
    If you mean a screenbar menu then you have to edit skins skinconfig file.
  • »22.10.20 - 17:22
    Yea, that one. Thank you, I'll try that. Interesting that it is not possible to edit it with MUI.
  • »22.10.20 - 17:34
    Korni
    You can configure screenbar menu to use MUI menus but it behaves a bit different then.
  • »22.10.20 - 17:58
