2nd monitor
    Posts: 88 from 2015/10/30
    I have an Apple laptop running MorhphOS connected to an external monitor. It works well. The question I have is. When I close the laptop lid, the monitor goes blank. Is there a way to prevent this?
    Thanks
    Donlad
  • »16.08.20 - 02:47
    Posts: 779 from 2007/10/23
    Good question:
    My monitor goes not blank.
    I can move the mouse pointer but unable to click...
  • »16.08.20 - 14:57
    Posts: 132 from 2017/8/7
    Kronos(?) told me a trick for that once. But i am old and can't remember. I believe you had to close the lid early during startup.
    [ Edited by amifrog 16.08.2020 - 22:07 ]
  • »16.08.20 - 21:07
    igracki
    Posts: 389 from 2003/2/25
    I don't think it's a good idea to close the lid while the Powerbook is running because of possible overheating problems!
  • »16.08.20 - 21:29
    But it is supported by Apple, iirc.
  • »16.08.20 - 21:32
    Posts: 2971 from 2003/3/5
    You mean *was*, right? Notice that OSX does disable the backlight though, right? That's because a PowerBook can't cool itself properly while it's closed. We'll try to see what can be done about the external display though. Which model is it exactly?
  • »16.08.20 - 21:57
    I can do it right now with my Macbook Pro, with, ehm, recent OS 10.9
    of course PPCs are a different thing
    [ Edited by amifrog 16.08.2020 - 23:11 ]
  • »16.08.20 - 22:10
    Thank you, my model is an A1138
  • »16.08.20 - 22:27
  • ASiegel
    Posts: 1370 from 2003/2/15
    This only worked up until version MorphOS 3.11. With the introduction of the extended dual-monitor support in MorphOS 3.12, this functionality sadly got lost. At least for the time being.
  • »17.08.20 - 06:47
