Boot MorphOS (and maybe OSX) from grub2?
  • esc
    esc
    Posts: 160 from 2013/5/27
    Hey folks,
    I'm using OSX Tiger, OSX Leopard, MorphOS, and VoidPPC on my Powerbook. I'm finding that grub2, the installed bootloader, doesn't play nice with OSX/MorphOS. Has anyone successfully gotten this to work? The built-in OF bootloader screen is painfully slow. Furthermore, when I have my USB mouse/keyboard plugged in, they aren't recognized early enough to launch the early boot screen.
  • »02.08.20 - 05:37
    ernsteiswuerfel
    Posts: 567 from 2015/6/17
    grub2 won't autodetect the MorphOS kernel. You have to read the grub2 docs on how to add boot entries manually. On OF-systems the kernel is the 'blessed' file on the small hfs partition.
    This should work without hassles as the kernel seems to be (is?) a regular ELF-executable which grub2 is able to load manually. Don't know whether this is true for OS X kernel too.
    Have not tried it myself yet, still on my to do list. ;-)
    PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.19 / Adelie Linux / Gentoo Linux] | A600GS [Amibench / OS 3.2] | Talos II Secure Workstation. [Gentoo Linux]
  • »02.08.20 - 08:33
  • esc
    esc
    I’ve been able to manually add the entry for MorphOS, I’m just unsure how to actually load it. I’ll work on this more today...spent a good four hours last night until about 2am and didn’t get far so I’ll take another look :P
    Thanks!
  • »02.08.20 - 15:58
    Posts: 12407 from 2003/5/22
    Tried this?
  • »02.08.20 - 17:36
  • esc
    esc
    Ah, nice. That does solve the slow OF bootloader screen. :) Thanks!
    The issues that I still have are basically:
    1. How would I be able to always boot to this screen? KVM connected USB devices aren't recognized immediately and I can't get to this screen without plugging an independent USB device.
    2. I have a Mac Mini G4 that boots into OS9 natively. When I do that (boot into OS9), MorphOS's "bless" status goes away. That renders the OF early boot menu basically useless as it pertains to booting MorphOS. When this happens, I have to manually go bless MorphOS to make it again recognized. Any way to deal with this issue spring to mind?
  • »03.08.20 - 02:21
